Question about Jenn-Air JCD2389G Side by Side Refrigerator
Refrigerator door won't close tight - Jenn-Air JCD2389G Side by Side Refrigerator
    Top Expert:
  • Jenn-Air Master
  • 12,650 Answers
Check and make sure unit level than feel around door to make sure seal had not popped loose and is bulging,finally if you have to adjust door will need help door heavy with door closed as far as it goes you need to loosen the upper hinge and lower slightly move door till flush and closed re-tighten lower first than top check door swing and readjust again it necessary
Posted on Sep 27, 2009
tborn6
  • 700 Answers
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
  • 13 Answers
SOURCE: The refrigerator door does not close with a tight
adjust doors on the top of machine the hinges move to adjust and leval them. hope this helps
Posted on Jun 06, 2009
Number5Gayle
  • 98 Answers
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Posted on Aug 09, 2009
EllaWatson25
  • 725 Answers
SOURCE: refrigerator door does not close tight
Either the cams and shims are bad or your gasket is bad. Look at the gasket, if it looks good, then the cams and shims are bad. Call us with the model number and brand and we will ship the parts to you. Hope this does the trick for you! Ella :>)
Posted on Aug 26, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Oct 16, 2009
Door wont close tight
The hinges may have to be loosened to realign the door to close evenly
Feb 01, 2013 | Haier Refrigerators
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the...
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Mar 30, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Refrigerator door
ice door won't close ge #pss26msrbss
Dec 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator Door (Whirlpool Gold)does not close like it shoul
You need to bend the door, if the gap is at the top put your foot between the frig door and the bottom and push the door closed slightly. so you can check it and do a small amount at a time. till tou reach the point that the door closes tight. if the gap is at the bottom put a shoe or something about 4 to 5 inches wide. go for it you can fix this..... saw
Dec 05, 2009 | Washing Machines
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice door will not close tight
You will need to re place the soliniod that closes door flap
Feb 22, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
795 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
