Question about Kodak EASYSHARE 5100 All-In-One Printer
How to print photos from my photo 4 by 6 tray?
reitann
  • 214 Answers
SOURCE: only 4x6 tray prints clearly
For this concern try pressing "copy+cancel" for media calibration then try again, make sure you have an A4 paper loaded. If this doesnt help you out try using the Kodak website www.kodak.com/go/itg and use "image quality" for class.
Posted on Nov 15, 2008
debroy
  • 174 Answers
SOURCE: printer won't print
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
Posted on Nov 27, 2008
  • 37 Answers
SOURCE: Will not print on paper from main tray
Your Printer needs that back installed, HP has a way of doing things, check to make sure the printer setting are correct on the computer.
Posted on Aug 10, 2009
  • 6 Answers
SOURCE: Printer will not print properly, say photo tray not engaged.
take out the photo tray if you can and put it back into its place /
turn off the printer and turn it back on . if it works fine if it does not ,the sensor is bad .
it gives you this message only if the paper try is not inserted properly or it is a false error message .
Posted on Aug 29, 2009
reitann
  • 214 Answers
SOURCE: looking for printing manuel for kodak easy share
The manual is available at www.kodak.com/go/manuals
Posted on Dec 24, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
I have a MAC OS 10.4.11 and an HP Photosmart 3210 all in one. I use Iphoto and have been trying to print a 4 x 6 photo from Iphoto directly to printer. No matter what I try the photo tray does not engage...
I haven't been able to make it work from photo tray either but I do put photo paper in main tray and change settings in Iphoto accordingly and print pics that way.
Oct 02, 2009 | HP Photosmart 3210 Printer
HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
Photos in Mac's iPhoto will not print from the photo paper tray. They always print on paper in the main paper tray (this is on an HP C7280 printer). I had an HP Photosmart 8250 and it was the same with...
This is an older post, but it appeared to be unanswered. In iPhoto once a photo is selected, you hit "Print" at the bottom right. A preview screen with options comes up. Once the correct options there are chosen, you need to hit print again - but it does not print yet. Instead a second "Print" window opens. In the middle of this window there is an "iPhoto" button with arrow buttons on the right. The arrow buttons open a drop down menu. Choose "Paper/Paper Quality" from that menu, and it will give you a button for "Source." The arrow buttons on the right of the "Source" button allow you to choose "Photo Tray."
Once it's changed, you don't need to redo it each time you print an additional photo, since iPhoto reverts to "Last Used Settings." But as a shortcut for future sessions, you can save these settings using the "Preset" button located at the top of the second "Print" window (the window where the "iPhoto" button is located). I used "Photo Tray" in the description so it would be obvious, since I don't print pictures every day.
Aug 15, 2008 | Office Equipment & Supplies
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
14 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
