Question about Brother Sewing Machines
Brother CS-6080 machine and tension problems
I have a Brother CS-6080 machine and am having major problems when I try to use it to thread the bobbin. It starts winding fine and then goes crazy and winds a big loopy, knotted mess. I can't find any way to tighten the tension on it. My sister has the same problem with her machine which is the same exact model. What should I do?
SOURCE: Winding the Bobbin
If you have a top winding bobbin on the right hand side it may be that the winder is seizing up, you must put a drop of oil now and again down the spindle otherwise it goes dry very quickly at high speed.
Posted on Jan 21, 2008
SOURCE: Janome sewing machine bobbin winder
I had that problem the first time I tried to wind a bobbin. What a mess. The next time I let the thread run through my finger and thumb before reaching the bobbin. I had to do the same on a previous Kenmore.
I've also found that the heavier Bernina bobbins don't 'jump' around.
Posted on Mar 25, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 180 - winding thread onto bobbin spool
Also it is quite possible that the small circuit board (P-print) just below the bobbinwinder that the motor plugs into has gone bad.
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
I have a brother CS-8072 sewing machine and need help winding bobbin. I followed the instructions in the manual but it didn't work.
What were the results of your bobbin-winding attempt?
Make sure the thread path is correct for bobbin winding and that the thread is seated in the tensioner. Most machines, it is better to NOT wind fast--although your machine says the opposite (???).
It looks like your thread comes off the spool goes to the left, through a guide, down to the front of the tensioner and the doubles back to go behind the tensioner before going to the bobbin. (Looks the thread goes counter-clockwise in front of the tensioner, then doubles back and goes clockwise around the back of the tensioner.)
Also, the problem may have to do with the spool type you are using. Try a different thread and spool--AVOID old or bargain bin threads.
If you still have problems, there is a stand-alone bobbin winder (called Sidewinder) for about $30 that is helpful to have. (Verify it will work with your machine's bobbins!) It is great because you can wind bobbins without unthreading your machine and it saves wear and tear on your machine.
http://support.brother.com/g/b/manuallist.aspx?c=us&lang=en&prod=hf_cs8072eus&flang=English&type3=348&type2=69
Apr 28, 2017 | Brother Sewing Machines
Brother cs-6000 will not sew, the top thread go through and tangles on back, and the bobbin thread is a straight line and can be easily pulled out, please help, trying to make kids school clothes
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Jul 09, 2012 | Brother CS-6000
Brother cs-80 tension issue
Remove the thread from the machine. Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread. Set the upper tension to the midway point.
Insert the bobbin in the bobbin case (make sure it is turning the correct direction) and thread the bobbin tensioner. Install the bobbin case in the machine.
Insert the fabric under the presser foot. Lower the presser foot. While holding the top thread tail with your left hand, manually turn the handwheel (always toward you, never away!) one revolution until the top thread has pulled the bobbin thread up. Raise the presser foot and sweep both threads under the presser foot toward the back (you can use a stiletto, a pencil, or some other tool to sweep the threads). Lower the presser foot, gently hold both thread tails with your left hand and slowly turn the handwheel (either manually or by motor) to form a couple of stitches. Then let go of the thread tails and continue sewing.
If it continues to cause thread nests or you have other issues, then your machine may need service.
Apr 01, 2017 | Brother CS-80
I get major tangles with lower thread and cannot sew. I've cleaned the shuttle and machine, changed needle, thread, bobbin and wonder if the shuttle is damaged....How could I tell? If so, is a...
It could be a mechanical problem but before you do more first check your UPPER tension. If the upper thread tension is too loose and the bobbin tension is tight you can get looping on the underside of the stitch. So pull on the upper thread and feel if there's tension there. You can try to increase the upper tension and see if that helps.
Jun 19, 2011 | Brother CS-80
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
Mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Aug 22, 2009 | Brother CS-8060 Computerized Sewing...
Brother CS-6080
Adjust thread tension. More tension higher number
Jan 14, 2008 | Sewing Machines
Sewing Machines Logo
166 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
