Spin cycle spins, but does not eliminate a lot of water
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
More than likely Blockage at pump, Try cleaning filter
Posted on Sep 27, 2009
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
My hotpoint wmm39 aquarius extra washes but does not spin
you are in an unfortunate delemer. It is either your spin winding thats gone or the control board or timer thats faulty. Normally a technician has spares to test against to prove by process of elimination.Aquick test, pull the pressure switch pipe off the drum assy. and retry spin cycle. Alao take note if all water is drained out of the tub. Let me know
Sep 25, 2009 | Hotpoint WMM39 Front Load Washer
Neptune w-9 spin cycle does not eliminate all the water
It sounds like a locking mechanism problem which is in turn the wax motor needs replaced and also the control board(mother board). your spin cycle is probably not performing the high fuction spin it needs to eliminate all of the water
Aug 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 80 Series Won't advance to spin
You will need to replace the timer. Let me explain why;
After the agitation cycle, the machine will enter a drain mode where the basket will not spin, only drain. After some time, the timer should 'pause' causing the machine to engage the spin clutch. The timer contact has become stuck, not allowing the pause, thus never entering engaging the spin clutch.
Jul 02, 2008 | Washing Machines
Hoover 500m spin cycle
That sounds like a broken motor couplin, slack drive belt, or worn bearings.
A repair person can determine which is it. I cant tell from here. However,
If you do this test you can eliminate one of the above. Lift the lid of the washer, hold the rim of the inner-tub and spin it clockwise and then anti-clockwise. If it spins both ways, you have a bad bearing which needs replacing.
May 31, 2008 | Hoover Nextra HNT 2135 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Doesn't spin
THE COUPLIN BETWEEN THE MOTOR AND THE TRANSMISSION IS BROKE!  IT'S EASY TO FIX.
Oct 11, 2007 | GE WHRE5260E Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
