Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Just repaired my starter on a 20hp briggs and strat/reassembled all parts .at first the engine ran smoothly,after 2.5 minutes i shut it off .I restarted engine when it suddenly started to make a clanking noise! I thought something was hitting the flywheel ,after checking it It still made a very loud noise ?? I got a stethascope and pin pointed the noise to the right cylinder.sounds like a blown rod or a piston /No smoke ,has clean oil. no off balanced idle of engine.Help!!
    Scholar:
  • 108 Answers
I can't be for sure but based on past experience with similar situation, it sounds like a loose rod. When mine did the exact same thing I took apart the engine and the two bolts holding the piston rod onto the crank shaft were significantly loose. Tightened them down (thank god i didn't damage the crank shaft) and it was fine. Good luck, let me know what you do.
Posted on Sep 28, 2009
Why does my B&S engine runs wide open even with throttle off 20 HP
Check the cable connection down near the engine, it should be attached to the throttle lever, it is not uncommon for the screws that clamp the cable to come loose
Jul 04, 2014 | Briggs & Stratton Starter Scott's Equip...
Ford tractor
How old is the fuel in the tractor? is it petrol or diesel powered?
Apr 14, 2014 | Cars & Trucks
Engine idoling way to high
An engine will idle too high because of : improper govenor setting, improper carb setting, intake leak, or missing carb throttle plate.
Oct 24, 2012 | Briggs & Stratton Starter Scott's Equip...
Why is my 20hp B n G Keep flooding?
check that the float valve is closing fully may have dirt under seat.
Aug 27, 2012 | Briggs & Stratton Starter Scott's Equip...
John deere with 20hp v-twin briggs and stratton. starter spins but wont crank engine?
remove the starter and see if the gear broke on the starter you can buy a new gear for about $10 but make sure you get the old parts out if your lucky the gear is just stuck from sitting
Apr 22, 2012 | John Deere Garden
The mower deck belt on my scotts s2046 comes off after a minute or so of operation. What's going on? Thanks
you should have some type of belt tensioner,most common type is a pulley with a spring to hold pressure on belt.Spring may be missing or stretched {2}belt could be stretched {3}pulleys may be out of alignment
Oct 05, 2010 | Briggs & Stratton Starter Scott's Equip...
Have a John Deere lawn tractor with 20HP Briggs V Twin. Engine ran great four 4 years (200hrs.) then started having fuel problem. Changed filter didn't help, changed fuel pump didn't help, cleaned...
You could try sending your question to the Customer service on the Briggs & Stratton Website. Maybe they will be able to explain and suggest a good solution.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro 20hp Tractor with B&S fuel flow problem
sound like to m e that your gas cap is bad if its not venting it will do that
Apr 16, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
120 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
