-   I recently purchased a new laptop. My old one is completely dead. My my wireless modem is locked and i do not remember the pasword or key code.
I also do not have the disk that came with the modem.
Hi Guest,
Harry has the answer for most routers. Netgear, Dlink, Linksys. Tthe reset is usually a tiny hole. Straighten out a heavy paperclip, and press it gently in the hole. It can in front or back. Hold it for 30 sec. On a very few, you have to hold the button in and unplug the router and plug it back in. The most common user name is admin, and the most common passwords are no password, password, and admin. Good luck!
Chechy,
The routers I have had will default to the factory password if you press and hold the reset button in for a while. On the linksys brand it defaults to ADMIN. Lookin the manual for your router and looker for RESET and you may find something similar to this in the instructions. If you don't have them you can find them on line.
Let me know if you need more help.
Was this helpful?
Yes
No
Solution #3
posted on Feb 19, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem... i have pressed the button in teh back, and it still does not reset the passwrod, i have a MN-100 base station
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
My Dlink DIR-625 Doesnt work at all, when I plug in the power, the only thing that lights up is the...
(More)
My Dlink DIR-625 Doesnt work at all, when I plug in the power, the only thing that lights up is the power led but it just blinks.
i forgot password of my linksys rv042 vpn router how can i recover it without resting the router...
(More)
i forgot password of my linksys rv042 vpn router how can i recover it without resting the router becoz they have a some special configuration on this. thanks gil
I use to be able to use my work laptop to access our server via a VPN but all of a sudden I no...
(More)
I use to be able to use my work laptop to access our server via a VPN but all of a sudden I no longer can connect. What happened?
I can establish a connection with a LAN cable and access the internet but the wireless light is...
(More)
I can establish a connection with a LAN cable and access the internet but the wireless light is showing a orange color and not putting out a wireless signal. It has worked fine for the last couple months. I rebooted twice and it will come on briefly for a minute and then shut the wireless signal off
what are the defult username and password for the 3 com router????
Comment by Guest, posted on May 18, 2008
Hi I'm trying to configure correctly E-mule in order to let it run faster and admiliorate my ID,that is now low.To approciate I need to enter the Zyxel program to let him recognize the TCP and UDP ports.I can't find the password to enter.I tryed with every word I could imagine,such as administrator,ADMINISTRATOR,password,PASSWORD,manager...and so on...Can anyone help me?
Comment by Guest, posted on May 17, 2008
Tryin to get wireless internet on Nintendo WII. And It is locked, so it asks me the password and i forgot it. The Brand is sbc and it is a 2wire 1800HG Router.
Comment by Guest, posted on May 10, 2008
don´t remenber my password
Comment by Guest, posted on Apr 05, 2008
I forgot my router home page username and password. Can anyone help me in retrieving it
Comment by Guest, posted on Mar 31, 2008
PASSWORD
Comment by Guest, posted on Mar 16, 2008
Want to add my lap top. and my pass word does not work
