Question about Motorola Mobility V551
I opened my phone now the screen is black. how
I opened my phone now the screen is black. how can I get the screen to work? Thanks.
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
My Samsung cell phone screen is not working; it stays black when I open it. It's a Samsung U600. It still works with exception of the screen...
Hi,there are there kinds of black screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage LCD the phone will detected,and thirdly, The flex of the phone.
The flex is connected to the screen and it makes the screen display,if the flex gets damaged it will make the screen display be affected.
i hope ,i will help you ,thanks for trusting fixya...
Sep 03, 2010 | Samsung Instinct Cell Phone
The screen on my Pantech Impact is black..i can make calls, text, listenin to music, & stuff thanks to the touch screen part of the phone. But when i flip it open the screen is black. So i cant take...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 10, 2010 | Cell Phones
My voyager's inside screen has gone black
do the buttons on the inside work? if so maybe you dammaged the video cable to the screen. if the buttons do not work then the phone isnt recognising that you have opened it. does the external screen go blank when you open it?
Jul 23, 2009 | LG VOYAGER VX10000 Cellular Phone
Screen problems
that mean your screen cable make lose or your screen mobile damage you must change it . when your mobile fill down this problem paper. :-(
Sep 05, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Camera is black
Have you tried opening the camera's lens protector? I know it sounds silly, but it took me a while to figure out... Turn the Silver ring (with 3 dots) clockwise to open the protector, turn it counter-clockwise to close it. Keep it shut when not in use to protect the lens.
Did that help?
Jan 09, 2008 | LG enV VX9900 Cellular Phone
Black Screen
Hi, before sending it in or taking it to a Motorola repair station, try this. Open phone turn it over so camera is facing you with finger behind and thumb of your right hand sweeze the area between camera lens and the vol up down button to reseat the ribbon connector that is located in that area between the cases. This worked for me and it is worth trying.
Sep 29, 2007 | Motorola Mobility RAZR V3
Phone LCD is very dull after water damage, rest of phone works
go get a torx screw driver and open it up stop turning it on that will only hurt it ... once you open it up dry under a lamp for a day and it will probably work
Aug 16, 2007 | Samsung SGH-T519 Cellular Phone
Motorola Mobility V551 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
