Garden Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i order a handle for a 14in Pullan gas
Where can i order a handle for a 14in Poulan gas chainsaw. I broke the handle and can't find a place on line that i can order parts for Poulan chainsaws.
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1383480
Points
7625
A few days ago i would have you here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html (poulan's part outlet)
They have locked the site to non dealers. Please go here:
http://www.poulanpro.com/node4020.aspx
To register your displeasure. They should be willing to help you with their product.
It used to be fairly simple to find parts. This new system will hurt their sales IMO. Tell them that! HTH
Lou
What could cause chainsaw not to start. It's not getting fire to the plug
If there is no spark it could be an HT wire or the magneto or the magneto grounding switch.
Gas leaks out of poulan 3400 counter vibe chainsaw handle.
The fuel tank is integral with the plastic housing of the saw. A leak has obviously developed, I would say its time to replace the plastic housing and go from there.
Where can I order poulan 2150LE parts at California?
hi there
jesnebres
pauly46 here
here is web site for parts it has breakdowns on just about every model
http://www.ereplacementparts.com/poulan-2150le-predator-type-gas-chainsaw-parts-c-16962_17147_17229.html
this site is cool its got helpful vids to show how to's
can order parts on this site
have a peek
cheers hope this helps
13helpful
I cannot find a replacement chain for Poulan 1514 chainsaw 1.5 hp 14"
Poulan PLN 1514 uses a 14in S-49 chain that is made by Oregon, the original chain has a part number 966-051501 that does cross to anything but the original has 49 drive links and S whith on the bar. This is available on Amazon for about $13.00 with postage Retail stores are charging over $20.00 for the same chain
How do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
1helpful
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
The dash number of your serial number is the type. HTH
Lou
1helpful
2answers
Need chain adjustment wheel part # for poulan pro model pp4620apx chsain saw
Poulan.com
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Starts ok when cold. acts like it's out of fuel when hot.
Clean or change the sparkplug. Also make sure you have fresh gas and the proper fuel mix.
Front handle broken
all you have to do is go to the web site and order a new one go to a true value or just look online for poulan parts
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
