Question about Brother MFC-230c Printer
My brother mfc-230c keeps saying "paper jam" and there is no paper jammed in the printer
    Sniper:
  • 59 Answers
This is an error that could get stuck in the memory, try removing the paper tray then unplugging and replugging the printer then when it's warmed up replace the tray.
if problem persists you may have a broken sensor
Posted on Mar 27, 2010
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
I TOOK APART A BROTHER MFC-3240C PRINTER AND CLEANED THE HEAD NOW IT KEEPS SAYING PAPER JAM PUT THERE IS NO JAM.WHERE IS THE PAPER JAM SENSOR LOCATED AT
well have you cleaned the head manually or by using the software thru the pc. if you have done so by hand it may cause aproblem try cleaning using the software and see id that helps.
Oct 03, 2010 | Brother MFC-3240C All-In-One InkJet...
My brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Apr 18, 2010 | Brother MFC-465CN InkJet Printer
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
Mfc 210c
If you are certain that you have removed all paper, try power-cycling your printer. Remove power cord and wait a minute or two then plug back in.
Jan 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Says paper jam but there is nothing in there
Can you tell me the jam code (if any), or where it is saying it is jammed?
Jan 10, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Paper jam
push menu then start mono (b/W) then 4x arrow-up button. maintenance should be displayed. What error code does the machine give to you?
Sep 11, 2007 | Brother MFC-410CN All-In-One InkJet...
Brother MFC-230c Printer Logo
286 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
