Question about Toro Lawn Mower With Toro Power Tools
This is only the second time I have used my Toro lawnmower and it won't start. I have pulled and pulled, can't find a primer button, checked the gas and oil (everything is fine) but it still won't work.
  • 148 Answers
Only the second use?? Take it back where you bought it and ask them to demonstrate for you.
Posted on Sep 28, 2009
Engine will start after priming but stops quickly (actually runs only very slowly and then stops).
Rheupel, Check that you have good fuel flow in gas line from tank. It sounds like a carburetor issue still, one of the ports are still plugged or float level is not set properly. Did you remove and clean emulsion tube in carb. If your carburetor is of diaphragm type, replace the diaphragm. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Small Engine Carburetor Rebuild Briggs Stratton FAQ
Commom Tecumseh Carburetor detailed rebuild from Toro Lawn mower lawnmower...
Lawn Mower That Starts then Stalls
LAWNMOWER REPAIR honda carburetor repair
May 19, 2016 | Garden
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 | Toro Garden
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
Lawn mower ran out of gas, after refilling it will start, run for a few seconds and cuts off. There is no primer button for this model.
It would be best to take this machine into a dealer like www.arcolawn.com and have the thermostat checked out. There were some early autochoke thermostats that would stick and cause problems.Best wishesJoewww.barter-joes.com
May 18, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
177 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
