Question about Toshiba Equium 7100S PC Desktop
When I update my display driver from standard VGA
Toshiba Equium. When I update my display driver from standard VGA on restart my screen splits in two as if showing two seperate monitors. The display settings shows two monitors but can't find how to switch off the second monitor.
  • 138 Answers
Hi, you can first boot it in safe mode,, then go the display settings,, from control panel,, then change the things,, where you can find,, double display.. and single
Posted on Sep 27, 2009
How do I get rid of a flashing message "Display Mode out of range"
Here is an article from Microsoft on this problem. Good Luck !
20x20_grey_minus.pngCause This behavior can occur if the signal from the video adapter exceeds the scan range of the new monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor. uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pngResolution To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Jan 24, 2015 | Computers & Internet
Hello.i just bought an LG L1742S-SF monitor and when i connected to the unit it shown the next warning:out of range and a certain frecvency.Can you tell me what would be the problem?Thank you
Apr 29, 2011 | LG L1742SSF 17 inch Monitor
My Acer Aspire 5580 turns on but has no display on the monitor. How can I solve this?
HI
can you try to start up with power key and also press the f8 key at the same time
now can you see anything if you can
go down to and try to click on repair and if that dont work on restart
then start up again pressing the f8
and try last good configuration and if that dont start up correctly then
try to restart again pressing f8 and try to go into safe mode when you probably will be able
to see the screen
and if you can go to device manager
scroll down to find the display
uninstall it and do a restart and hopefully windows will find new hardware and
reinstall the display correctly but it will probably just give you a standard vga driver
so on restart if you can then see your screen you could go to
start
programs/windows updates
check for new updates to see if there is a update for your vga
good luck
Mar 06, 2011 | Computers & Internet
Toshiba Satellite A100 PSAA2C video boot
have you tried installing or running the drivers disc for your laptop right after the windows installation without restarting it first? that might do the trick... it's either the driver for your laptop's board/ chipset or the vga driver...
Nov 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
I can load vga after formatting
Try Using Downloading and using the driver from this site :
http://www.laptopdrivers.net/toshiba-equium-l300-laptop-download-windows-vista-to-xp-drivers/
Or Directlink to the VGA Driver for it.
http://uploading.com/files/WS9G50H6/Toshiba-Equium-L300-Intel-Graphics-VGA-display-20080519181914-Driver-For-XP_-_ww...zip.html
But before using this one, just make sure you remove ..or rollback the previous one.
Jul 11, 2009 | Toshiba Satellite Pro L300 Notebook
Attention out of range is displayed on ibm 2 74 monitor
Apr 13, 2009 | IBM E74 17" CRT Monitor
Outof Range error message & black screen
To resolve this behavior, either change the refresh rate which is what is chnaged or the resolution or change the video adapter settings.
If the above problem does not help ypu then change the resolution and select the correct resolution which your CPU and monitor both support....
Try the below solution if you know it or else leave it
  5. Click Next, click Show all hardware, and then click Standard display types underManufacturers.
  8. After the computer starts, right-click the desktop, click Properties, and then clickSettings.
If the above solutions is not working for you then contact your nearest Harware person for the solution... All the best.
Mar 18, 2009 | HP L1940 19" LCD Monitor
Out of Range message displays when PC boots
The settings that you have for you tower needs to be changed if you have a old monitor connect that to the tower then right click on your screen go to settings and set it real low once this is done connect the new monitor up and set where you would like it,
The out of range is just letting you know that the settings thats set the monitor can see
Mar 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
hope it helps!
Nov 02, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor driver
you can set a resolution of 1440*900..
option 1) open device manager,, update the drivers for standard vga card.. locate ur video drivers folder,,(do it manually even if u have it on cd)...
option 2) this one is bit risky.... open add new hardware wizard and add ur correct video adapter, no matter ur standard display adapter is already installed. after you finish, update ur original standard display adapter and this time, it will pick the correct drivers.. now you can remove your dumb display adapter and restar pc .
risk is- be very careful, u dont want to remove your physical adapter by mistake, resulting no video after a restart.
Oct 17, 2007 | Microsoft ChiMei CMV938D 19" Widescreen...
Toshiba Equium 7100S PC Desktop Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
