Question about Onkyo TX-SR500 Receiver
Distortion When I play a cd in surround sound I get some very distorted sound cannot tell if its just the sattilite speakers or the mains. The speakers are bose accoustmass 10. When playing a dvd there is no distortion
  • 151 Answers
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Posted on May 27, 2008
Philips Electronics 46PFL3908 46 sound distortion
sounds like you burnt up the amp chip only way to fix is to replace thw whole circuit board
Mar 24, 2014 | Philips Electronics 46PFL3908 46" 1080p...
Denon AVR 1508 distortion on left channels
I have a different model, but sometimes suffer this when power outages or other strange things happen. Its usually the microprocessor getting confused and not doing its job properly, once none of the speakers came on at atll!
In the handbook, it will tell you how to do a factory reset - that always sorts mine (Same brand, Denon). Just a pain setting it all up again.
You should be able to find a PDF version of the handbook online if your's is misplaced in the house move.
Dec 17, 2013 | Audio Players & Recorders
My panasonic SA-PM193 died after 3 hours of playing music after i added a 4 inch subwoofer and 2 small speakers
... whatever that tells us.
If you severely modified the load to the amp by running more speakers than it's designed to drive and/or at a lower impedence, well, are you surprised?
It only pushes around 25 watts/channel AT TEN PERCENT DISTORTION through a carefully and unrealistically limited bandwidth specification.
http://audio.manualsonline.com/manuals/mfg/panasonic/sc-pm193_1.html?idRes=699618
Running 'clean' (under, say, 1% distortion throughout th 20-20000hz range) it probably only pushes 10 watts/channel. Once an amp is taxed beyond it's clean abilities it will start to distort, badly, and distortion will kill speakers and maybe the amp itself.
Sep 23, 2011 | Panasonic SC-PM193 Micro SystemMicro Audio...
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Left channels do not work when using surround modes
Ohhhhhh, so it has NEVER worked for YOU and it needed fixing when you got it. That changes everything. And you don't have the manual??
You can find the manual on Retrevo.com. Just register and download it. You're going to need it to make use of this unit anyway.
Make sure everything is connected correctly.
Look it over and play around with it. Speaker setup needs to be done before anything else. Did you get the microphone that comes with it? If not, go to page 23 and start there.
Feb 16, 2010 | Denon AVR-1708 Receiver
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
Distortion
Your speakers are worn if you can try someone else speakers. Speakers tend to wear out with excessive use particularly when played once or twice loud its a try that wont hurt at least for peace of mind you may need not throw them out.
Sep 28, 2007 | Boston Acoustics MediaTheater Computer...
Onkyo TX-SR500 Receiver Logo
235 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
