Question about Bose Lifestyle 20 System
What size screws do I need to fix Bose jewel speakers onto the small stands? I lost the original screws in a house move. The missing screws are the ones that fit downwards into the top of the speaker stand (through the casting that you mount onto the back of the speaker) I have a lifestyle 20 system bought in 2002 (in Hong Kong). The speaker stands are the short Bose stands that you use to mount the speakers on a shelf and came with the system. Thanks
  • George Scott
    George Scott Jul 10, 2017
    Since you going to the hardware store take the stand its a M4X25mm=mini metric wont find it ...get close ...use teflon tap
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
SOURCE: Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Posted on May 17, 2008
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
cjackHD
  • 71 Answers
SOURCE: Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
Posted on May 31, 2009
Need screw size for stand
Take the Stand to the hardware store and have them try a few sizes that fit. You need Machine Screws and who knows what length?
Jan 05, 2014 | Hanns.G HL269DPB Black 26" 5ms Widescreen...
I have a bose 321 system. When it is plugged in, I get a pop through the 2 small speakers. The 2 small speakers work but the large one does not.
The only way to fix this it must go to Bose. They repair on sight at the factory and replacements are original, there is no authorized centre other than Bose. I would go online and check for a phone number and find out about pricing and see if service is still possible.
Mar 23, 2012 | Bose Cinemate Digital Home Theater System...
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
I have 5 bose jewel speakers. can I use one of them as center speaker? Second, can I use bose jewel speakers with Pioneer VSX-1020 AV receiver?
I imagine you could but you must consider their impedance (probably low) and make sure to manage the bass so it goes elsewhere. Define them as SMALL.
If you have multiples to use I'd recommend wiring two of them in series for the center to 1) increase the impedance and 2) move more air. Proceed cautiously with the setup and usage until you assess their ability to handle the power. Listen for any signs of stress.
Jun 17, 2011 | Pioneer VSX1020K Receiver
Need screw size for Bose 901 Lifestyle speaker to mount to PS6's
Had the same question, e-mailed Bose support and they suggested "# 10 woodscrew, 4.5 mm diameter".
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
Ok…
Tools:
large pliers
C-clamp
Instructions:
Aug 29, 2007 | Bose Lifestyle 12 System
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Screws missing on F707 body
Without looking at the back of my 707, I would say your best bet would be a watch repairer. Your local jeweler does not repair watches but sends them out: find out where they send them. Usually located in some jewelry center.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Bose Lifestyle 20 System Logo
272 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
