I have a GE turntable microwave counter top oven that beaps after a few minutes of being plugged up to an outlet and goes to 0 on the screen. The error message is F3. Do you know what that means and should I replace the microwave? This microwave is about six years old. Thank you so much for your help.
The door handle has broken twice .... I even taped it with heat resistant tape ... the tech said...
(More)
The door handle has broken twice .... I even taped it with heat resistant tape ... the tech said that I was cleaning it with chemicals and that caused the problem, so this time I used just water to clean and it happened again. The micro is further away than the recommended height from the stove. Is this a common problem with this model? This is the third time already. the handle is plastic. JOB
how does one open the vent/boost/light cover for the GE JVM2050 microwave oven? The three switches...
(More)
how does one open the vent/boost/light cover for the GE JVM2050 microwave oven? The three switches have detached and are sliding inside... (bad build quality)
