Question about Boss Micro BR Digital Recorder
When bounce tracks on my micro-br there seems static going on
When I record a track on my micro-br it sounds completely normal, but once I bounce 2-4 tracks into 1 track, all of the sudden the sound gets staticy.
I need help on this because I do not want to send crappy staticy songs to my friends.
  • 4 Answers
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Posted on Oct 13, 2009
  • Boss Master
  • 5,603 Answers
You might want to go to the VSPLANET.COM site as they deal with a lot of these type problems.
The setup and levels are important and it is easy to cause overdriven levels when merging the tracks.
Posted on Sep 28, 2009
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
I have a BR-600 and when I record tracks over one of the drum patterns, it is getting into the habit of going out of synch when I play it back (usually after I have left it for a day and come back to it) -...
If you turn the power off between uses you will LIKELY have to resync the tracks. I doubt the unit remembers anything about sync to canned drum patterns once you turn the power off.
Try leaving it on and see if it acts the same.
Mar 18, 2010 | Boss Micro BR Digital Recorder
Boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
Jan 31, 2010 | Boss Micro BR Digital Recorder
I recorded music on track 3 and a voice on track 4 but when ever I try to record to CD disk I only get music and no singing
You have to bounce your tracks to a sstereo pair of tracks. Have a look at this document:http://cms.rolandus.com/assets/media/pdf/MICRO_BR_Q_A.pdf I hope this helps.
Nov 26, 2009 | Boss Micro BR Digital Recorder
I need help with my Boss Micro BR. I want to convert the song I recorded to MP3, so that I can hear it on my laptop. I connect the recorder with the laptop through U.S.B. and can only get to the files that...
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Oct 05, 2009 | Boss Micro BR Digital Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Oct 18, 2008 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
152 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
