Question about Refrigerators
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
We woke up this morning to find our frozen foods defrosting in our refrigerator. (Kenmore Elite model 106.50509990 side-by-side) Vacumming out the coils under the unit was of no help. Every few minutes the relay (attached to the side of the compressor) clicks (on?) and then clicks again (off?) about 5 seconds later. The top of the compressor feels somewhat hot. From what I can see there is no ice built up behind the back panel of the freezer. What really seems funny is that the refrigerator side still seems to be cool, but the freezer side is rather warm. The repair company is backed up and cannot come out until Thursday (3 days). Can anyone please help. Thanks.
  • 1 more comment
  • k6_user Dec 18, 2007
    Yep, that did the trick!!!
    Thanks very much peyton32034, you truely are a "Guru"
    Thanks,
    Drew
  • seeking4help Jun 05, 2008
    hi, our refrigerator relay keep running every few minutes but both the freezer & refrig are not cold at all. we had a repairman came out and replaced the relay with a starter cap. It works for month and now the same problem seem to come back. we called the same repairman and he told us that we have bad compressor and the refrigerator is not fixable. can the compressor be replaced and how much? could replacing starter cap instead of relay caused the compressor to burned out?
    thank you in advance for your help.
  • Anonymous Mar 30, 2014
    Compressor icing refrigerator vents
  • 410 Answers
The relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Posted on Dec 18, 2007
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Kenmore Elite stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
My Kenmore freezer model # 970-257320 is no longer keeping food frozen. Suggestions?
IF the unit is not self defrosting and there is ice, you may have ice blocking the evaporator coils. If the unit is self defrosting and is not completing a defrost cycle then the defrost timer is bad.
Apr 30, 2015 | Kenmore Refrigerators
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have a Kenmore Model 59672912200. Not cooling. All food defrosted or cool. Refrigerator keeps coming on and off.
2 possibilities....faulty start relay (mounted on compressor),or bad compressor...try relay first,good luck
Mar 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
May 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Dec 26, 2007 | Refrigerators
Dec 17, 2007 | Refrigerators
Refrigerators Logo
2,030 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
