Question about Fantom Drives 120 GB Hard Drive
I have the sample problem with the green light turining red
I dont hear the fan turn on either and the drive is not identified by the computer. Solutions?
    President:
  • 1,015 Answers
Could be a bad tranformer for the power supply. Test the transformer with a fluke meter and make sure the output voltage matches the rating on it. If it does not then replace it. You could also dis-assemble the housing that holds the drive and install it in the computer and see if it is recognized. If those things don't work then the drive might be dead. You could try to partition and format the drive when it is installed in the computer. This might repair the drive but you will lose all saved data on the drive. If there is data on the drive you do not want to lose you can send the drive to a data recovery specialist....but that will cost some bucks.
Posted on Sep 27, 2009
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
DO NOT PLACE IN A FREEZER !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
How do I get my computer to turn on it is saying no signal?
1st, it is the monitor that says, "No Signal." That being; is the actual computer turned on?
If it has a green / red power light and you can hear the hard drive and fan running inside the computer case, then check the cable that runs from the back of your monitor to the back of your computer's case.
It may be disconnected of just bad.
If you cannot hear any noise inside the computer case or there is no power light on, then check the electrical cord in back of the computer's case to the wall. If that is good, check to see if there is a light switch that turns that socket on and off.
Jun 02, 2015 | Computers & Internet
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
It was wired for a 4 wire flat trailer plug. the plug was ripped off and now there are wires coming from both tail lights and the drive lights on rear passenger and trailer dont work. Green, Black, brown/w...
You need to install a 3-2 wire converter. I suggest a CURT 56175 then
1.Using a test lamp, identify the corresponding wires in the harness for the left turn, right turn, tail lights and brake lights. 3. Temporarily remove the vehicle's negative battery cable from the battery. 4. Using wire taps, attach the input wires of the tail light converter to the corresponding vehicle harness wires identified in step 2 as indicated.
Converter Brown Wire: Tail Light Circuit Converter Yellow Wire: Left Turn Circuit Converter Red Wire: Brake Light Circuit Converter Green Wire: Right Turn Circuit
5. Locate a suitable mounting location for the ground eyelet on the vehicle near the converter on vehicle's frame or cross member.
And your ready to tow!
Mar 08, 2011 | 1999 Plymouth Grand Voyager
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Red light on power up. No image on monitor. Pc fans working.
On a computer mainboard there are usually a number of connecting pins right next to one another called RESET, POWER LED, HD LED etc.
The power led often leads to the green LED next your power button to show that the juice is available and on. The cable that leads to the red LED is usually the HD LED which shows that a disk drive is being accessed.
Since the red LED is active, one of your disks is probably being accessed and that's where the problem is. Either the disk is damaged, the cable is still not inserted properly or the bios is having problems identifying one of your disk drives.
1) Power the computer off. Take the power cable out. Make sure that you are grounded (have no static charge on your body). Take all of the cables between your mainboard and your disk drives off.
2) Plug in one of your disk drives, reconnect the power cable, switch the power on and watch the monitor. If all goes well you will see that the bios has recognized the disk drive and will simply display a message that the operating system for example isn't available or no harddisk drive is present (if you connected something other than a harddisk drive).
3) repeat this process with the other drives, powering the pc completely off each time and then adding a new disk drive.
4) once you've reached the point where the red LED drive is displayed but no message is available, you've found the culprit that is keeping your pc from booting properly. Hopefully the cable has just been stuck on improperly or the cable is damaged (Check it), rather than you having disk drive damage.
Mar 27, 2009 | Aspire Red X-Cruiser Mid Tower ATX Case...
My pc dont start
The problem identified that your system wont start. By solving, let begin from the very the very start. 1. be sure that power supply function well. u can test PS by changing temporary identified functional PS. if u sure that PS is good then, examine processor. remove memory. switch on system w/out memory if hear beeping. u are sure that processor is working.if not then something wrong with your processor. if beefing then insert memory. if not solve, examine memory clean it very well. and insert. if same problem replace memory. notify me if more problem identified. we will continue.....
Dec 14, 2007 | Systemax Venture PC Desktop
Fantom Drives 120 GB Hard Drive Logo
199 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
