Question about Kodak EasyShare V610 Digital Camera
My camera error # e 45
Same problem error # e 45 displaying on my kodak V610 camera and lens cover is not closing
    Genius:
  • Kodak Master
  • 1,099 Answers
This is a lens fault and unfortunantly the cam. needs a repair.
In order to arrange the repair: Pls. contact your dealer or KODAK directly:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=4248
Posted on Oct 13, 2009
Hello, I'm from Indonesia introduce doctoral pocket digital camera. to the problem of error 45 on kodak V610, V570, V705 caused by a focus motor carry. I often deal with the problem that I have about 430...
Error 45 usually shows up when there is a problem with the camera's lens. The camera locks up to prevent further damage. On some Kodak models, there is a notation in the user's manual that only says that the camera needs to go in for service.
So, what can you do? Try taking the camera and tapping the edge nearest the lens hard against your hand several times. This can dislodge any grit that might be jamming the lens. Turn on and test.
Clean with canned air. Using short bursts about 2 inches away and at an angle so as to blow any debris out instead of deeper in. Go around the lens turret and then test.
(At your own risk) set the camera on a tabletop and look at the lens to see if it is out of alignment. If it looks off center, push the lens toward the greater gap until you hear a click. Turn on and test.
If none of these work, then your camera needs to be physically examined by a repair technician.
hope this helps.
Feb 23, 2011 | Kodak EasyShare V610 Digital Camera
Error message E45 comes up on camera - What can I do to fix it? Kodak easyshare V610. Message comes up when camera turned on. Batttery charged etc.
Is the lens extended? If so, try hitting the lens a couple of times with the palm of your hand and then turning off the camera. Turn it back on and let me know what happens. Sounds crazy I know, but those things are notorious for that error and that problem. You can also try taking out the SD card and see if the error goes away. Let me know what happens. Thanks.
Jeff
Nov 23, 2010 | Kodak EasyShare V610 Digital Camera
Errer #45 kodak v610
The problem seems to be with your lens guide it is out of track so please follow the step below,
Try forcing the camera lens but be careful while doing this if something goes wrong your camera our lens can be damage
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
If no luck then contact your Kodak service centre
Thank You
Oct 01, 2010 | Kodak EasyShare V610 Digital Camera
I have kodak_easyshare_v610_digital_camera an...
hi, error #45 is the same with lens error and one of the lens unit is damage.your camera has two lens assy and the damage one is the lower part that always used. there'e only 2 possible way to work your camera 1.To adjust or clean the lens unit and the 2. To replace the whole assy.bring to service center and request first for estimate charge before you proceed to repair.
thank you
May 19, 2010 | Kodak EasyShare V610 Digital Camera
Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 18, 2009 | Kodak EasyShare V705 Digital Camera
Camera blanks out with message- error 45 and its not coming on
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EasyShare V610 Digital Camera
V610 error 45 whatcan i do
i bought a kodak v610 a few years now- no problems until a week ago. while using the video it just blanked and said camera error see e#45 or something like that. it wouldnt shut down (the camera lens wouldnt close) so i had to remove the battery and such. anyways i checked the manual and did what they said- i erased all pics from the memory card. then i charged the battery. but the problem still persists. i tried taking a picture- it did 1 and then when i clicked review and back to camera it blanked again with the error. nothing is working. its just not coming on.
Jul 04, 2009 | Kodak EasyShare V610 Digital Camera
Lens needs to be manually opened
I just repaired this problem on my daughter's camera today! I took out the 4 tiny screws that hold the front cover on and discovered gunk and goo that were keeping the lens from retracting. Please note the exact position of the screws. They are different sizes. I then very carefully cleaned all the residue using Q-tips dipped in rubbing alcohol. It worked perfectly! Just like new.
Jun 20, 2009 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
1,588 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
