Question about Karcher 2500 PSI Pressure Washer
Will run with quick start spray. Otherwise, will
Will run with quick start spray. Otherwise, will not start. Has oil, clean filter, fresh fuel.
  • 3,600 Answers
Try replacing the inline fuel filter in the tank that should do the trick if not post ere for more information.
Posted on Sep 27, 2009
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
I have a CS 440 chainsaw. Accidentally placed chain oil in the gas/oil chamber. Cleaned it out quickly but now the chainsaw will not run. What else can I do?
The filter, fuel hose, and possibly the carb is now full of chain oil, pull the fuel pipe off the carb, with the fuel filler cap off blow through the pipe to clear any oiltrapped. now replce the filter on the end of the pipe, go through the start procedure, if it still will not start, remove the air filter and drizzel a small amount of fresh fuel oil mix straight into the filter elbow, this should start the engine, if it stops again repeat the process until it clears itself.
Sep 19, 2011 | Echo Garden
Draper petrol lawnmower wont start
Check the fuel...most often stale fuel creates havoc...YOU MUST FLUSH THE TANK donot add to old crumby gas, YOU MUST clean out the carb(remove the fuel bowl and carb spray all the tiny openings,orifices, check the air filter, check the oil, Add NEW fresh fuel, and hit with a quick spray of starting fluid just prior to restarting...should run out well.
Jul 24, 2010 | Garden
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My gas pressure washer fell in the pool while running. Is it a goner?
Maybe, there is a slim chance it died before sucking water into the cylinder and cracking the head. To try and fix it drain out all motor oil buy a can of carburetor cleaner and spray the engine out remove the oil plug and the spark plug and spray some wd 40 into the spark plug hole, replace the air filter dry the spark plug and clean the fuel tank and replace the fuel filter inside the fuel tank replace oil with fresh oil and then give it a try. You’re out $20.00 but if it runs you are one lucky person.
Sep 23, 2009 | Honda Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Karcher 2500 PSI Pressure Washer Logo
297 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
