Furnace Blower Motor Specs
I need to replace a blower motor in a Tappan furnace, I dont have the specs for the motor but i do have the m/s#. Ijust need the specs....H.P. ....RPM....i know its 120V and 3 speed but nothing else. thanks
Thanks...I did end up going with a universal motor, works just fine. Thanks again for the input.
Posted on Dec 21, 2007
  • 447 Answers
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Posted on Dec 18, 2007
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
I am getting one light flash indicator limited circuit issues. The furnace fires and heats up but blower does not come on
Remove the blower motor, With the furnace circure breaker off!!!!!!!!!!
Put a universal 115 v plug on the two wires and hold it on the floor and plug ER in. It's a 115 motor, look at specs to make sure. If she don't , check wholesale house to get a motor. If not that, motor capacitor, then contact switch if capacitor don't do it. Be very safe!!!!!!! . The capacitor will need to be discharged and if checking it, do NOT
Touch both post. Discharge it before disconnecting it by turning all power to furnace off, taking a screw driver and putting it across both terminals. It will arc. Do that a couple three times to get rid of stored electricity. If it does arc with a little snap and spark, it's good.
BE SAFE. Hope that helps.
Jan 21, 2015 | Frigidaire PTAC Electric Heat 9000 BTUs...
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
Hi i have an goodman capf036a2a furnace and when i cut on the heat the burner light but the blower motor doesnt turn its makes a humming noise and the code it reads is #33 roller blowout. do i need to...
Since the motor is humming we know it is recieving voltage, try spinning the blower wheel by hand and see if the motor starts up, if it does the capacitor needs to be replaced, if not the blower motor needs to be replaced.
Nov 28, 2012 | Heating & Cooling
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Mar 12, 2010 | Heating & Cooling
Furnace lights fan comes on then fan goes off furnace stays light until overtemp takes it out code flashes 4
Have some one hold the bottom door safety switch, turn furnace on wait until heating fan relay clicks, and check at terminal (Heat) & terminal (neutral or where all the white wires are located on the control board) for 115 volts to 120 volts. If voltage is present replace blower motor, if voltage drops out while running then replace control board.Turn power off to furnace, open bottom door and feel blower motor with hand, if motor is real hot replace motor. you can not oil this type of motor, it has to be replaced along with the compacitor. Good luck.
Jan 22, 2010 | Goodman Furnace Draft Inducer Blower ...
I have an old Magic chef furnace and need to replace the Fan Motor were can I find the fan spec for replacement? It was built in 1987 Model # G8A75DC10-17 Serial# A 10221CKA Forced Air Furnace Categorie I
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Oct 06, 2009 | Heating & Cooling
How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
464 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
