Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
B&S Intek 20HP, first minor ticking, then rough running (like missing one cylinder), then mechanical clunk . . . now zero compression! What should I look at first? Can valves and valve gear be replaced without engine removal on ride-on mower?
  • 468 Answers
You can replace the valves without removing the engine by removing the head first. The valves will come with it, however, the mechanical clunk isn't usually indicative of valve issues. I would remove the head, and push on the piston to see if you threw a rod instead. Sounds like the connecting rod was knocking, then gave way, and now the piston isn't moving at all. Another way to tell, is just to put a screwdriver in the spark plug hole, and turn the engine over by hand and see if the screwdriver moves. If not, you need to tear the engine down and fix your rod issue. If you're lucky, you may find the the end cap bolts came loose, and you can put it back together without too much issue. Otherwise, your engine's probably done.
Posted on Feb 01, 2010
2000 3.3 dodge missing like its running on 2 cylinders
Dont start it up anymore till pull the front cover off and check the timing belt as it sounds like its stripped a tooth and jumped over and now its banged the valves but i am known to be wrong with my diagnostics but check it out anyway .
Feb 14, 2012 | 2000 Dodge Grand Caravan
20hp B&S Intek will only run on one cylinder. I thought it was one of the magnitos, but realized if I remove the spark plug wire to one cylinder the other would run...just not both at the same time.
It sounds like you are having the same problem I had. If your model has inline diodes in the ignition wires running to the coil packs the cylinder that isn't running has a bad diode. My dealer tried to order a complete harness but they back ordered it for weeks. I finally went to an electronics shop got one and soldered the new on into the harness. Problem solved. P.S. don't go to radio shack they don't have squat. Good luck!
Oct 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I HAVE A 20HP SINGLE CYLINDER INTEK ENGINE IN MY LAWN MOWER THAT SURGES BAD AT IDLE UNLOAD NOT SO BAD. CAN YOU SUGGEST WHAT TO DO two year old
Carb needs to be cleaned Clamp your fuel line Get some jet spray gumout with the tube take fuel bowl screw out of the center of the bowl this is where your high speed jet is Dont loose the fuel jet on the float it hangs there clean it as well the rest of the carb inside put back together should run better
Feb 27, 2011 | Briggs & Stratton Garden
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Ticking noise coming from engine, loss of power, runs very rough!
check inj thay do click but not very load but becuase it might be it damaged it is doing this
Aug 10, 2009 | 1996 GMC Jimmy
My B & S fouls plugs, runs rough, almost stalls when blade
THE PROBLEM SOUNDS LIKE THE CARB IS RUNNING TO RICH OR TO MUCH GAS IS BEING PUMPED INTO THE CYLINDER. IS THERE ANY SMOKE AND WHAT COLOR SMOKE
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
644 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
