Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Hi I have a chamberlin lift master Professional formula 1 garage door opener and the lights use to time out but now they stay on.
    President:
  • 3,197 Answers
The relay that controls the lights is most likely bad. This is a unfortunately a common problem after electrical storms.
Posted on Sep 28, 2009
Changing code on keypad
i have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Jan 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
The light on the Garage door blinks but doesn't stay on.
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Hello I have a chamberlin 1/2 HP chain drive how do i know if the sensors are lined up correctly?
The sensors each have a small light on them. One of the sensor lights stays on all the time and the other sensors light will only come on when they are pointed properly. If you cannot get the light to come on you have bad sensors.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Lift Master Formula 1 is not closing all the time. It will close about 1~2 feet the reverse and reopen. This happens using the remote and the manual button. Also, after it reopens the light blinks...
I recommend this to everyone with garage door opener problems:
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4.
Gary
Dec 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Our Lift Master Formula 1 garage door was working fine, then all of a sudden it would not open. When you hit the remote you hear a click but nothing from the the opener. The sensors have not been touched...
It sounds like you may have had an electrical storm or power surge. Remove the logic board and check for loose, missing or burnt traces on the printed circuit.
Oct 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberline 1/2 hp belt drive opener that stops opening
It sure sounds like a broken spring. Sometimes the break can be difficult to see. How heavy is the door to lift manually. This will give you a good idea.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light Problems on garage Door Opener
Its possible there could be a problem with the circuit board, the other possibility is that every time you break the beam of the photo-eyes located at the bottom of the tracks, the lights come on for another 4.5 minutes (if it is a chamberlin brand opener).
Feb 13, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
317 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
