Question about Electrolux Washing Machines
Hotpoint Aquarius WM62P will not operate.
My Hotpoint Aquarius WM62P would not operate after set-up, without a thump on the door to start it, this has gone on for months every thing working ok otherwise until yesterday when the thump refused to work it's magic. now I know there is a door interlock switch fitted but don't know if it's electrical or mechanical, if faulty could this switch be the problem. thanks.
Sorry if this is a repeat Q.
  • 822 Answers
Yes.......could be the interlock.....
cheap part to try first..
cheers
Posted on Aug 03, 2017
2 Suggested Answers
freddyboy45
  • 9 Answers
SOURCE: Hotpoint Aquarius will not start.
I'm old fashioned and am not familiar with the "duff door interlock switch" term. However, you are familiar with the fact that there is a switch that is activated when you close the door. That switch or a post that pushes that switch is not doing it's job.
Could be that the switch is not working properly or the post is broken.
Posted on Sep 27, 2009
Testimonial: "Thanks Freddy I have ordered a new switch today."
My Hotpoint Aquarius WM62P won't drain. I lowered the drain hose into a bucket and it drained so it's the pump or filter right? So I unscrewed the lower back panel to locate the pump and filter but I...
Use a pair of pliers (like water pump pliers) and use them to grab and pinch open the metal spring clamps. then while holding them open, move the spring down off of where it was so that you can pull the rubber tube off of where it is connected on.
Mar 13, 2011 | Hotpoint Washing Machines
hello you will have tip it on it's side slightly so you will need to people do this and reach from under neath hope it helps
regards
shaun
Mar 13, 2011 | Washing Machines
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
Sep 27, 2009 | Washing Machines
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Sep 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Aug 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA34
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Oct 27, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
