Question about RCA D61130 61" Rear Projection Television
Rca D61103 picture rolls side to side - RCA D61130 61" Rear Projection Television
  • 161 Answers
Call Rca and have them reset it. I would start there. On your remote you may have a aspect button. That allows to adjust from widscreen to full screen.
You may also want to check your screen saver mode because that does do that when its in that mode.
Just go into menu on the remote.
Hopefully that will help.
Good luck.. if no luck call RCA.. They should be able to reset it over the phone or check their web site first.
Posted on Sep 27, 2009
RCA 42" LED TV Has Picture Issues on Half of the TV
It sounds to be a back-light CCFL lamp fault. Check the lamps for uniform illumination all the way. See whether there is dakened ends to them.
Jun 07, 2013 | Televison & Video
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
Picture on rear projection t v is bowed in at the sides and picture is blurry. color is ok.
Go to menu then setup see if you see convergence ,if you do not then you have a blowed fuse FL231 it will be on your deflection board over on the right side of your FBT flyback Transfomer there is 3 in a roll small brown rectrangler looking caps but they are fuses it will be the one in the middle.
Dec 30, 2009 | RCA HD52W59 HDTV Projection Television
My RCA big screen TV picture now looks like 3D without the glasses. The picture also bows in at the top and bottom in the middle of the screen. What would cause this?
Go to menu then setup if you donot see convergence on menu then you have a blowed Fuse FL231 it will be on Bottom board to left side onthe righht side of FBT flyback transfomer there is 3 of them in a roll small brwn rectangler looking caps But are fuses the one in the middle is it. Call Mats for fuse 1-800-628-1118
Sep 26, 2009 | RCA Televison & Video
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
Is there a simple fix for my projection rca P52929 ? It wont hold a channel and the picture rolls after about 15 minutes
is the reception clear? if yes only rolling picture. check the vertical section for leak capacitor or change value resistor.
Aug 11, 2009 | Televison & Video
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture rolls on playback
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
Feb 25, 2018 | RCA CC617 VHS-C Analog Camcorder
RCA D61130 61" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
