Question about Acer Computers & Internet
No sound on computer speakers - Acer Computers & Internet
  • 600 Answers
Check device manager for conflicts and also check audio & sounds in control panel to be sure the volume is up
Posted on Sep 27, 2009
My speakers are plugged in correctly but no sound is coming out of the speakers
Do you get sound out of the computer speaker (inside computer)? If not, go to device Manager and see if the sound drivers are loaded. If not, you will have to find the drivers and load them. If you sound from the computer speaker, then I would try the speakers on another computer that you know works with external speakers to ensure the speakers are good.
Apr 01, 2011 | Harman Kardon HK206 Computer Speakers
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
I am unable to get the speakers to work at all. They will not play system sounds or anything. Troubleshooter suggested that I uninstall and reinstall the speakers. So I uninstalled and went to reinstall...
I don't know what is the operating system you are using with your computer.Still we can check, first we need to find out if the problem is with the speaker or with the computer.
Try these steps
  • connect those speakers with other computer check the sound, if you are getting sound there it means speakers are ok need to check computer audio setup and hardware.
  • If you are not getting any sound connecting speakers with other computer then it is speakers need to replace.
Incase speakers are ok Disconnect the speakers
  • restart the computer,check if there is windows sound if not
  • right click on the volume control icon on the left hand button corner of the screen,uncheck the mute option.still not getting any sound?
  • try to download the audio driver from the dell support site.still not getting
  • need to check the internal speaker connection,if it is fine
  • go to this website http://www.kellys-korner-xp.com/xp_tweaks.htm and click on Restore sound -windows Audio service and run the tweak,YOU NEED TO USE INTERNET EXPLORER
  • still you cannot hear the sound change the internal speaker.
Sep 26, 2010 | Dell A215 Computer Speakers
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
My speakers are not working on my computer. I put
Sounds as if you lost the audio drivers for your sound card. Go into your Control Panel and call up SOUNDS. Double-click on any sound listed and see if you get an error message stating you don't have a sound card.
If that's the case, go to the website for your brand of computer and search for the audio drivers for your make and model computer.
Nov 11, 2009 | Benwin S-20 Computer Speakers
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
My speakers will not play on my computer
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
Speakers
  1. first findout the problem is due to speaker or from your computer soun driver or hardware.
  2. for checking speaker, connect to an ipod or walkman to the speaker input if it works the speaker is okay
  3. check the computer sound driver software may installed properly
  4. for these type dxdiag on run in the start menu
  5. check the sound driver problem, if it re install the sound driver by using its cd
Jan 18, 2008 | Labtec Pulse 285 Computer Speakers
Speaker
even thou your computer doesnt have any sound it still can record sound.  i think you have a defective speakers or sound cards.  try check on it...
Oct 14, 2007 | HP P5302M Computer Speakers
Computers & Internet Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
