GE washing machine
The washer will agitate fine but it will not spin when it gets to the spin cycle.
  • 262 Answers
Pending the age the motor can be bad being this the newer models have a electronic controlled motor by taking the front cover off using a putty knife in the slit going across the front push in on each side with putty knife and pull out on front cover then look at the top of the motor you will see a flashing light (newer models only) it should flash a repeated timer console is the tech sheet which will tell you the other codes. but before you go through all this check your lid switch
Posted on Dec 18, 2007
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Jul 08, 2009 | GE Washing Machines
you can view this site to have some ideas about your agitator problem.
any further question let me know.
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
