Question about Janome Sewing Machines
Janome presser foot "P" error
I keep getting an error that says presser foot "P" X.
I tried putting the presser foot up then down and re-starting but it is giving me a re-occuring error?
  • 182 Answers
SOURCE: MC 11000 janome stops reading presser foot "p"
This is a relatively easy adjustment as I just did one last week but I'm not sure I can explain it. Anyway, open up the lamp cover and look at the top of the presser bar. There is a sensor that is easily adjusted. It has a small phillips screw that you need to loosen. Then move the black 'L' shaped piece either up or down a little (I can't remember which way) and re-tighten the screw, you may need to experiment. The 'L' shaped piece is a flag that goes between two sensors when the foot is raised and can be rotated left and right about 10 degrees. I hope that helps.
Posted on Feb 08, 2009
  • 3 Answers
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Posted on Aug 04, 2008
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
  • 14 Answers
SOURCE: feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Posted on Mar 19, 2009
  • 190 Answers
SOURCE: Pfaff 1471 presser foot does not go down
This procedure is SPECIFIC TO THE PFAFF 7570. It MAY work for you. Try at your own risk.
Needed tools:
Small flat screw driver.
Large Phillips screw driver
Small torx screw driver
Large torx screw driver
Small cleaning brush
Small scissors and long tweezers.
Machine oil.
Old tooth brush.
Dish detergent.
Lots of care and patience.
In this particular case, perseverance was the winner. I'm quite handy with mechanical things, so I had to partially disassemble the machine until I found the cause of the problem. The foot presser mechanism DOES have a spring, but it's concealed and out of sight. I never suspected it, but that was the case. When I found it, white grease that was put there at the factory to lubricate its movement had turned into a think sticky gunk. That was what was holding the foot presser in the up position. This gunk was so stubborn! I had to clean the spring, the housing and a plastic pin really well, and then oiled all the components inside their housing. More below.
The shaft of the foot presser is hollow at the top. This is designed to hold a 1-5/8" spring and a 5/8" black plastic pin that's inserted at the top of the spring and protrudes from the hollow shaft.
Start placing the 7570 on a table that has a height that's comfortable for you. You'll be standing and squatting a lot to accomplish the task.
Standing behind the machine, and looking down, there's a metallic plate on your right that holds the thread tension discs. This plate covers the shaft, found underneath, and holds together the mechanism with the round wheel with numbers that protrudes slightly on the side of the machine's body.
Several pieces had to be disassembled in order to get to this plate, although at this point I'm doubting whether or not so much work was necessary, since I was so excited upon the discovery that I forgot to notice whether I could have found the spring and remove it without having to disassemble so many pieces.
The metal plate is black and thick, and is held down with a heavy gauge black machine screw. The plastic pin makes contact with the underside of this plate, which compresses the spring when the foot presser lever is up. Once the lever is disengaged from its locked or resting position (in the case of the embroidery position), the compressed spring pushes the entire foot presser down, as it DID when I first bought the machine.
These are the disassembly steps, without diagrams, but use your imagination as best you can to picture my description.
1 - Top cover removal.
The top cover (the one with the different built-in patterns drawn on its inside face) is held in place by two thin black metal plates where it hinges. A little bit of pressure towards the outside on the top of one of the plates (on either side) will release the pivot pin on one end, and then a little jiggle in the same direction will release the other. Put the cover aside.
2 - Concave top cover removal.
This cover is the one that houses the thread spool in the horizontal position, if that is your choice when sewing. It is held down by two plated machine screws, one short and one long. After removing the screws a little jiggling will help removing it, pulling it mainly upwards. You may need to put the large handle up, to allow for more movement. Put it aside once removed.
3 - Side cover removal.
This covers the area where the foot presser is housed, on the left side of the machine, as you face the buttons on the front of the machine.
Standing behind the machine, once step 2 has been achieved, one can see from the top, looking down, a large black machine screw on your right hand side, just inside the cover. You don't need to remove it completely, just about 1/2 turn will loosen the pressure to release the cover. Pull the cover outwards and sideways and set aside. You may want to also remove the light bulb, to be able to get to the mechanism to clean it, to remove pieces of thread that may be lying around or caught in the different moving parts. Push the light bulb gently in while turning it counter clockwise. You'll feel it disengaging from its socket. Pull it out and set it aside. Clean it if necessary. Use the scissors and the tweezers to remove any lint and debris.
4 - Pressure discs plate removal.
I'm not 100% sure now that this can be done at this stage, but continue. If this particular plate cannot be removed, because other components get in the way, then skip to step #4A below and come back here later.
Standing behind the machine, looking down at the housing, you'll see another large black machine screw holding down a black metal plate. Remove it completely and put it aside. Next, remove the plate, gently nudging its way out of the different obstacles that may be present. One of them may be the sewing shaft mechanism. If this is the case, gently turn the wheel manually to cause the mechanism to move up or down, as to allow more room for the plate to be completely removed.
Make sure you lift this plate slowly, as to prevent the spring and plastic pin from spilling inside the machine's body. Put the plate aside. Now you see the black plastic pin, perhaps stuck inside the hollow part of the foot presser. If so, pry it loose gently and clean it with a sudsy solution, and use an old tooth brush to remove the gunk from its coils. Do likewise to the plastic pin.
While you have the housing exposed with lots of space, I would suggest you should remove any debris, dust, etc, and oil all the moving parts with sewing machine oil.
5 - Assembly.
This is done in the reverse order. Congratulations! You've done it!
Additional steps, if metal plate in step 4 above cannot be removed after step 3.
4A - Front plate removal (The one with the colored buttons and LCD display).
Standing behind the machine, looking down, you'll see a grey ribbon cable crossing the case from back to front, under the main shaft. Remove its connector by pulling it up gently. No force or tools are necessary. Bend the ribbon to one side and set it aside, out of the way.
Squatting a little from the same position, looking inside the foot presser housing, you'll see two small plated screws, close to the edge of the housing, one towards the top and another towards the bottom. Remove completely.
In the same squatting position, and moving your attention to the main machine housing, you'll see the green PCB board. It's held by at least three screws. One of them, on your extreme left, is not visible because it's concealed by a plastic insert at the top of the left end of the 7570. This insert is held down in place by a thin black metal plate. This plate has a tiny hole where the top cover of step 1 hinges.
Gently turn the small torx screw holding down this plate 1/2 turn counter clockwise to release the pressure. Once loosened, slide the plate slightly towards your right. This will allow you to pull the insert up.
With the insert out of the way, squatting again, you'll see the third plated screw on your left. Remove it.
Turn the machine upside down and ensure it's not rocking from side to side.
Use the large torx driver to remove the machine's base. This base contains a power supply box, and another green PCB board. It's connected to the rest of the machine with several ribbon cables of different colors. The base is attached by 4 machine screws. Loosen the screws completely and remove using the tweezers.
Raise the base from the right end, allowing its other end to rest on the edge of the inverted 7570 body and stand it at 90°. Inspect the location, orientation, and general layout of the cabling. You may need to unlatch one or more plastic holders for the ribbons, which hold them flat and organized. Remove these holders to have greater access to the connectors.
Jot down the order of the different ribbons and the way the are inserted into their sockets on the PCB found inside the base. Fortunately the connectors are of different sizes, and there should be no way to insert the wrong one in the wrong socket, but it's best to be safe. Jot down order, color, etc.
Gently pull on the different connectors from the PCB board. A little bit of force is all that is needed. Push them aside one by one in order to allow you to see more and create more space.
Next, disconnect the large power cord. You need to insert a small flat screw driver to release pressure on the sides of the socket. Do it one side at a time, and then gently pull it out. Set the base aside. You're almost done!
Next, looking down, pushing the ribbon cables away from you, you'll see two plated screws in each corner of the inverted 7570 housing, on the side closest to you. Remove completely. At this time you should be able to remove the face plate, gently threading the widest of the ribbon cables through the opening on your left, in order to put the base aside.
With the face plate out of its position, put the machine in its straight up position and step 4 above can be accomplished.
Now, I also did remove the 7570 main handle in order to create more space and see more in the reduced area of the foot presser housing. If you too find it necessary to do so, use the corner of the tip of a small flat screw driver to pry the lock ring open, being careful not to allow it to spring out of your fingers and falling inside the case. Slide the pin out and then the handle itself, horizontally.
Go back to step 4 above if you came here because you could not do step 4.
Posted on Aug 23, 2009
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Posted on Jan 03, 2010
0 characters
1 Points
No knob to adjust presser foot pressure. Space between feed dogs & presser foot is too tight to pull a piece of fabric out with foot down. Diagonal seams get pushed out.
You should not be able to pull fabric from the machine when the presser foot is down. The presser foot should always be raised before removing the fabric.
Are you trying to darn or quilt something without the feed dogs activated? If so, there are special presser feet for that purpose that are shorter in height (ie darning foot) which allow more space between the presser foot and the stitch plate so the fabric can be moved freely.
Apr 17, 2015 | Janome Sewing Machines
How do I adjust the presser foot pressure on my Janome 7100QDC
your model doesn't have this feature Janome 7100QDC Computerized Sewing Machine , it it did, there would be a knob on the top left of the machine above the presser foot which you could screw up or down to increase or decrease the pressure. Its not a feature on many machines, the presser foot bar has a big spring internally which applies the pressure and this will just adjust to suit the fabric under the foot.
Mar 01, 2015 | Janome Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Why does the needle keeps getting stuck in the bobbin
Sounds like you've got a thread jam going on. Take the bobbin and bobbin case out, take the needle plate (=throat plate) off the machine, and clean all the lint and bits of thread and other gunge out of there. Reassemble. Rethread with the presser foot up. Fetch up the bobbin thread and pull bobbin and top thread ends under and behind the presser foot. Then start each seam like this:
1. Fabric under the presser foot; lower needle with handwheel or needle up/down key into the beginning of the seam.
2. Drop the presser foot.
3. Hold the ends of the bobbin and top thread behind the presser foot while you take the first 2-3 stitches
4. Drop the thread ends and sew normally.
See also the last pair of photos here:
Feb 10, 2014 | Janome Hello Kitty 11706 Mechanical Sewing...
The presser foot on my Janome MC9000 will not go up or down
yeah the cam lever is probably broken. Time for a new machine???
Oct 24, 2012 | Sewing Machines
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
there are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Nov 24, 2010 | Janome Memory Craft 5700
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Jan 01, 2007 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
139 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
