Question about Maytag Neptune MDE5500AY Electric Dryer
Lights just blink on the dryer...same problem
The dryer doesn't start at all. Lights turn on from left to right on the panel. when the lights are all turned on, the lights turn off and the sequence starts again from the left.
  • 986 Answers
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Posted on Sep 27, 2009
Testimonial: "Thanks for the suggestions. I'll check them out. I'd still like to know why the panel lights turn on the way they do."
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
2005 Pontiac Grand Prix front left turn signal went out, I replaced the bulb and the light comes on but the turn signal still doesn't work. If I have the lights sent on automatic the right parking
Hey I literally just today had the same problem, put a new bulb in the light was on but did not blink!!!! SUPER EASY SOLUTION, you simply have the bulb in too far. I gently pulled mine out a tiny bit and it started working fine... guarantee that's all that's happening to you!!!
Jan 25, 2013 | 2005 Pontiac Grand Prix
My right signal doesn't blink but the bulb lights are on
If the left signal light is affected as well then the flasher can is faulty.
The flasher can is located under the dash.
Jan 08, 2013 | 1995 Buick Park Avenue
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
The Right Turn Signal comes on, but doesn't blink on my 95 Buick Park Ave. I have a State Inspection coming up and need to get it fixed by this weekend.
It sounds like one of the signal lights is out. The best way to find out is to turn the hazards on and check if they blink. If they do then you might need a turn signal relay.
Good Luck
May 11, 2011 | 1995 Buick Park Avenue
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Maytag Neptune MDE5500AY Electric Dryer Logo
119 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
