Menu Disabled ibm infoprint 1332 - Office Equipment & Supplies
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 300 Answers
SOURCE: ibm infoprint 1332`
It's quite straight forward
1. Remove the left door.
2. Remove the right cover
3. Remove the paper support
4. Remove the redrive cap
5. Press the fuser wiper cover latch and remove the cover.
6. Remove the top cover screws
7. Remove the paper bin full sensor flag assembly from the mounting bracket
8. Remove top cover.
9. Remove 3 screws and the cables, the printhead will now come out.
10. After replacing the printhead run some test prints with the cover off, loosen the 3 screws holding the printhead to make any adjustments needed to insure the print is straight.
Posted on Jun 20, 2008
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
  • 13 Answers
SOURCE: IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Posted on May 19, 2009
  • 18 Answers
SOURCE: where do you install the fuser cleaning wand?
On the top of the machine (right where the paper lands after it prints) there is a small cover you can open by pulling it to the side and then up. The wand goes there (on top of fuser and under the cover) Make sure you pull the old one out or the new one will not go in the hole.
Posted on Apr 05, 2010
HOW TO CHECK PAGE COUNT OR USAGE ON IBM INFOPRINT 1332
Hold the check mark and left on power up will get you into the diag menu.
Oct 22, 2015 | IBM Office Equipment & Supplies
Infoprinter 1332 dirty copies just on one side. fuser changed March 2008
Replace the wiper blade in the cartridge and clean the primary charge roller inside on roof.
Feb 25, 2011 | IBM Infoprint 1332 Laser Printer
Somebody has a Manual of IBM 1332 infoprint printer?
drivers and owners operating manual are almost always free for download from manufacturer's website. look for support or help sections.
Sep 07, 2010 | IBM Infoprint 1332 Laser Printer
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
Apr 14, 2010 | IBM Infoprint 1332 Laser Printer
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
Infoprint 1332
in valid cartridge refill
Oct 21, 2008 | IBM Infoprint 1332 Laser Printer
Print Cartridge
Unfortunatly, no. This is the compatibility list for that part number: IBM2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
May 14, 2008 | IBM Infoprint 1332 Laser Printer
Memu Disabled
Try, turning off the printer hold go and return button and turn on the printer until you see the memory size ( 64 k or so) let go of the buttons and it should go to the settings try to print test pages and so forth, then if you can go to exit diagostic mode.
( This is actually a Lexmark printer probably a T620 or T630)
Oct 04, 2007 | IBM Infoprint 1352 Laser Printer
Maintenance shedule error
Power off the printer and hold down the two top right buttons and power the printer back up. You will be taken to a menu that you will be able to scroll through. Look for the "Maint Count Reset" option and press the "enter or go" button and reset the count.
Aug 17, 2007 | IBM Infoprint 1332 Laser Printer
118 people viewed this question
jasbo
jasbo
