My KitchenAid Superba top load washer lid switch assembly screw housing broke as the plastic snapped off from someone dropping the lid too often. I have found the replacement, but am unsure of how to replace it. I suspect I have to open the washer, but cannot find a repair manual for my machine. I have looked in the common places for the Model # and cannot find that either, but the part I found online matches the look of the piece that I have in my hand. Any assistance would be greatly appreciated.
  • 220 Answers
Model number should be on the tub opening at the base of the lid. check out this video and see if it helps you out.
http://www.youtube.com/watch?v=FNRd04vwc4Y
Posted on Sep 27, 2009
  • 3,600 Answers
You can go to this web site and get on the phone help with your machine and with a picture and how to take it apart.
http://www.appliancepartspros.com/Appliance-Parts/Washer-Parts/index.aspx
Hope this helps if you still need asstance please reply to this post.
How to change the lid switch on a sears 90 series washer?
have to remove the panel or housing. is that a kenmore model? if so u just remove panel housing by removing the 2 side plastic panels ( these small plastic panels just snap off) then unscrew 1 screw on each side located on top of appliance. then the whole body or housing can be pulled forward and removed.inside underneath u will see the door switch which can now be removed
Oct 19, 2014 | Kenmore Washing Machines
What is a code E2
kds e2 means lid switch is not being engaged .remove rear top cover .2 phillips screws .3 snap clips use flat blade screw driver to pop cover .look at rear of lid (door) right side plastic arm part of lid snaped off replace lid part xqb5526f.1.3-3 check saftey switch manually over ride switch as a test .if machine spins change lid if switch broken as well change both .switch # xqb550.1.6
Aug 10, 2010 | Avanti Top Load Washer W797
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
How Old is Kitchen Aid Washer model#KAWE577BWH1 Serial#CE0804943? Spin Cycle not working
Your washer was manufactured in 1995 and is made by Whirlpool. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Jul 09, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Whirlpool washing machine "lid switch" is broken My lid switch came completely apart! I have a grey plastic switch (paddle) and two tiny springs. How do I lift the top of the washer to re-assemble the...
Found online:
Disconnect everything, power first. Keep the drain hose above the top of the washer if the bucket’s full of water. If there are clothes in it, remove them to a water-tight location (like a cooler or something).
Put the unit on an appliance dolly and get it onto the driveway before removing the drain hose from the rear of the unit. Water will gush out for a while here.
Unscrew the two hex bolts at the top of the unit that attach the plastic tabs to the console. Unscrew the screws in the end caps that attach it to the top of the cabinet. Unscrew the two hex bolts at the base of the rear panel that attach it to the base.
Pull the console forward and up a little to dislodge it. Slide it out of the way enough to get access to the two brass clips. Put a flat-head screwdriver in the hole towards the front and pry the clip forward a little to release it. Remove both clips. This releases the rear panel from the top of the cabinet.
One cable goes from the console to the top of the cabinet: this is the lid switch. Disconnect it.
Pull the cabinet forward now that everything is detached. It helps to have someone holding the console and rear panel while you do this. Remove the cabinet.
Place it on something to prevent scuffing, like a few towels or a small animal. The lid switch is the only device here. Unscrew it from the ground (one hex screw) and from the inside of the lid (two Phillips screws). Push the grey tube holding the wires out of the clip holding it in and release the plug from the top of the lid.
Take this to a parts shop and ask for another. It’s around $25-50 depending on how desperate you look.
Snap the gray tube back in, screw in the ground and switch. Close the lid: it should click now. If not, check that you actually screwed the new unit in properly. Yes, the new one.
Replace the cabinet and the rear panel, then the clips and the console. Replace all screws and bolts. Make sure there are no spare parts. Reattach all the cables and hoses and plug power in last.
Test it by putting it on a small load and let some water into the tub. Then stop it, move to spin dry, and start it with the lid open. Nothing should happen. Close the lid (you made sure to replace the drain hose, right?) and it should start spinning and pushing out water.
Congratulations, you saved over $100 and only lost a few hours of your life doing it.
And now you know where my morning went.
Pro tip: don’t let the lid fall down anymore. Place it down, don’t drop it.
Dec 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 Series Washer
this came from my research of the web...
Lid switch broke off (plastic housing broke in half at the screws). This definitely gets easier after doing it just once. Took me a while to figure out I needed to pop off the plastic caps on the sides of the top control panel, to expose the two screws that others mention. Remove the two screws, lay the control panel forward exposing the two metal clips on top holding the cabinet in place. Unhook the clips, voila. The plastic connector of the replacement switch didn't exactly match the old one so I cut and splice (wire nuts and tape). Cleaned everything well while I had it all apart. If I ever have to do this again, it should take a fraction of the time.
im sure its the same as yours.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
Ice chute door
THE FACE PLATE OF THE DISPENSER ASSEMBLY SHOULD HAVE A SLOT ON THE BOTTOM CORNERS. INSERT A LARGE BLADED SCREW DRIVER IN THE SLOTS AND TWIST. IT WILL SNAP AND YOU WILL THINK YOU HAVE BROKEN IT BUT IT DIDN'T. ONCE THE BOTTOM IS RELEASED, PICK UP ON THE FACE PLATE TO DISENGAGE IT FROM THE TOP OF THE ASSEMBLY. IF YOUR DOOR FELL OFF, THE CHANCES ARE THAT A PLASTIC LOOP BROKE OFF THAT THE HINGE PIN SLIDES INTO. A FIX KIT HAS BEEN DEVELOPED TO REPAIR THIS PROBLEM. BEST TO BE INSTALLED BY A FACTORY AUTHORIZED SERVICER. IT CAN BE DIFFICULT.
I HAVE INSTALLED TWO OF THEM MYSELF.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba top load washer not working
You have a lid switch and bracket. Most likely it is one or the other.
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
520 people viewed this question
Top Washing Machines Experts
