Question about Honeywell Programmable Thermostat Heater
Programming the thermostat
The heat barely gets up to 60 and i need it to be at least 70
  • 1,420 Answers
It may not be a thermostat issue. It's very hard to help you when you only give us 16 words to go on, so I want you to do the following and get back to us.
Provide us with a make and model number of your heating system.
If the heating system has air filters, check and replace them if needed.
Make sure that the heating elements or ducts are not being blocked by furnature and that you can feel heat or air movement from all.
Tell us if the heating system is cycling and/or staying on al the time or not coming on at all. This will require you to move away from the thermostat and find the heating unit.
The more you can tell us, the more we can help you!
Posted on Dec 19, 2007
The furnace comes on @ 70* when programmed to be 60* at night
you have to switch it to settings and reprogram it. find your owners manual and it will tell you how to program your thermostat
Dec 01, 2012 | Honeywell Programmable Thermostat Heater
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
At what temperature do I program the thermostat for a comfortable cooling(at how much do set the cool and h ow much should I set the heat). Thanks for your help
Normal settings are heat 70 and cooling 74 to 76 I like 76 if your not active its fine. They say the every degree above 70 heat cost additional 5%.
Jul 02, 2011 | Honeywell Programmable Thermostat Heater
This unit has a manual thermostat. Is there a way
60 IS A DREAM TEMP MOST UNITS WILL NEVER REACH THESE TEMPS. THERE NOT MADE TO. AT 60 YOU LOWER THE HEAT ABSORPTION INSIDE AND OUTSIDE AND WITHOUT HEAT IT BEGINS TO ICE UP WHEN IT IS 70 INSIDE AND 70 OUT SIDE YOU WILL ICE UP 75 IS GOOD SETTING. IF YOUR TSTAT HAS A HOLD BUTTON SET TEMP AND PRESS HOLD THAT MY HELP
Apr 20, 2010 | LG LXA1030ACL Air Conditioner
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
I have the thermostat set for 70 degrees on the white rodgers programmable thermostat. The heat runs until the room is 70 degrees, but then the heat stops and the room cools off and the heater doesn't kick...
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
Jan 03, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Dec 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
