Question about Maytag MSD2454G Side by Side Refrigerator
MSD 2554 ARW won't cool
Maytag MSD 2554 ARW won't cool bought 12/98. should I repair or replace?
  • Bruce Hathcock May 11, 2010
    Well if you can afford a replacement By a new one it will be more efficient and sine we are going to increase the tax on electicty next year by %15 percent the savings in electricity will pay for itself. Plus the government is giving out credits for buying a new appliance. Otherwise you can get it fixed but could run into upwards of $300.00 to fix.
Cub cadet 2554 GT just stalled and won't turn over?
check the fuses and cables safety switches
May 25, 2012 | Cub Cadet Garden
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
I have a Maytag MSD 2756GE refrigerator. When the icemaker fills with water, the water also comes out the water dispenser in the door. I am currently using a cup to catch the water that comes out
UHG.. SHUT OFF THE WATER.. YOU WILL NEED TO PULL OUT THE FRIDGE AND CHECK THE VALVES ( SOLENOIDS )THERE IS 2 OF THEM JUST FALLOW THE WATER LINE, SOMETIMES THEY CAN BE CLEANED, I WOULD SHUT THE WATER OFF TILL THESE GET REPAIRED ! IMPORTANT ! .. THE FRIDGE WILL FREEZE UP AND STOP COOLING PROPERLY !! .. JUST USE ICE TRAYS AND A JUG OF WATER UNTIL YOU HAVE TIME TO REPAIR ..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | Refrigerators
Pav2200agw/arw not spinning. have changed belt but still isn,t spinng
If your pump ain't locked up, your lid switch and motor are fine then I would say you have a worn out thrust bearing. The main pulley releases the brake on this bad boy when the motor reverses and lets the tub turn free. With age the pulley wears out and won't release that drum.
I have a manual and a wonderful repair tutorial on the thrust bearing replacement HERE
Thanks for using FixYa
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2011 | Maytag Washing Machines
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Is my compressor must be replace?
The easiest way for you to find out is to bear the expense of buying the start relay/overload assembly mounted to the pins of the compressor, along with the run capacitor. If this starts it and runs with low amps, like 1-3, you're likely safe. Don't buy food for 24 hours. Sometimes the compressor won't seize again for hours afterward if it has been allowed to cool down before replacing relay.
Aug 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
82 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
