Question about Dell Latitude E6500 Laptop
I am having problems connecting to internet. I
I am having problems connecting to internet. I always have to do the diagnoise and repair before it will connect
    President:
  • 2,600 Answers
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Posted on Sep 27, 2009
Can i drive if the power steering light comes on
you can but I would strongly suggest that you go to a shop and have the problem repaired or you could loose steering and cause an accident. the light comes on when there is a code set in the module to help start to diagnoise the problem
Jun 22, 2014 | 2006 Pontiac G6
I have my laptop HP pAvillon dv4 1225dx having problems in connecting in our router. i experienced tis problem after having it repaired for its damaged flex cable for the display. but before having it...
The antenna connection needs to be repaired, On many models it's part of the flex cable, I suspect the repair person didn't quite get it seated correctly. On MOST models, it's a separate cable. It may have been damaged or unseated during the repair. I'd start with a friendly call to the repair person, saying I am having a problem with the wifi since the repair. Refrain from saying 'since YOU repaired..." The first says only a timeline, the second is accusatory. You're more likely to get the person to fix it free that way.
Apr 03, 2017 | TP-LINK TPLink (TLWA730RE) Wireless Router
When I start my 94 mustang gt the service engine soon light flashes twice. The car rev higher than normal as well (around 1500 rpm) and idles rough to start. After I drive it for a bit in runs better. ...
sounds like you have a code in the computer that needs to be checked out which will send you in the direction to diagnoise the problem.you could have a couple problems.it could be a tps sensor,vacume leak,injector problem,etc.
May 19, 2011 | 1994 Ford Mustang
Sirvice airbags message stays on my 2005 2500 HD Silverodo
when the light comes there is a code set in the computer and will need to find out what the code is in reference to the air bag circuit before you can start a diagnoises to repair problem.
Mar 18, 2011 | 2004 Chevrolet Silverado 2500HD
Check engine light always on sometimes flashing
A flashing Check Engine light indicates a potentially serious problem somewhere. If you are not familiar with reading the computer codes, take it to a good shop and have the problem diagnoised and repaired.
Oct 30, 2010 | 1999 Ford F150 Regular Cab
I am having trouble staying connected to the internet wirelessly. I put in the correct WEP password and start out having full strength bars but then it says that i am not connected to the internet (a...
If you are using a wireless connection.. It is always advisable to disable the firewall setting.. Please do that so your connection will be stable...
If connection failed or disconnect try repairing your ip address...How?.. on the lower right portion of your desktop in the taskbar you will see 2 small icons of monitors... right click on this... then click "repair" Do this always if connection failed.
Hope this help you..
Much appreciated if you rate this help...thanks
May 22, 2010 | Linksys WRT160N Wireless Router
Connectss to wireless, variable connection to internet
I would check Services to see if some like WLAN Autoconfig is set to something other than Automatic and is changing with Demand. Try setting anything to do with networking to Automatic if it already isn't.
Jan 23, 2010 | Acer Aspire One PC Notebook
Problems connecting, stuck on aquiring network/renewing IP addres
i want to down load the mother board drivers and utilities c.d,how will down load
Sep 01, 2009 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Belkin wireless G+ usb adapter
AOL has been and will always have problem (had to do repairs on AOL computers since 1994)
If you have a DSL or Cable connection why pay again for AOL? That means you are paying twice for the same internet connection - and AOL causes lots of problems.
For AOL problems, it is best to contact AOL.
Jul 21, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Problem in internet connection
check fire wall setting if u have a back up for ur security soft remove it from the computer and try disabling all startup items
then check
May 19, 2008 | Compaq Presario M2000 Notebook
Dell Latitude E6500 Laptop Logo
147 people viewed this question
Alun Cox
