Question about Kenmore Washing Machines
Kenmore 70 series, will fill up and agitates but will not drain or spin out
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is an excellent description by GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. Basically, a 1/2" extension drive for a socket set. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
Posted on Sep 27, 2009
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
My kenmore series 70 will not spin or drain the water out
open your washer put a screwdriver in the lid switch hole set the machine on spin tell me what happens be careful the tub should spin out the water
Apr 30, 2009 | Kenmore 23822 Top Load Washer
Won't agitate or spin
Probably the motor coupling has cracked. Located between the motor and transmission/gearbox.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
