Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Problem with Samsung LE40S86BD starting up
The T.V is approx 2yrs old and recently it has had problems starting up. The relays click in their on/off cycle a nukmber of time before the T.V eventually starts up. On average it takes between 1 - 2 mins to turn on. Is there any advice that anyone can give me please.
3 Suggested Answers
  • 29 Answers
SOURCE: keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Posted on Jun 27, 2010
SD Tech
  • 14553 Answers
SOURCE: panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Posted on Nov 05, 2012
Trying to start my 2000 chrysler 300m I get a
sounds like a starter relay or selonoid (clicking )sound then nothing ? that will be built into starter.
Sep 02, 2014 | Cars & Trucks
2004 kia sorento ex cranks but not start
Did you change the fuel filter?
Feb 12, 2014 | Cars & Trucks
I have a Samsung LCD tv approx 4 year old. When u come to switch it on the standby light flashes and makes a click as though it is switching on then it'll click again and switch off. It will go through...
There is a problem with the power supply, which may be due to bad electrolytic capacitors. Alternatively, there may be a bad relay in the power supply.
Feb 22, 2011 | Samsung Televison & Video
HELLO I have an LG fridge w/bottom freezer model Problem with the LG Refrigerators I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the...
i think that you have diag the problem it is the relay on the compressor . at it age the relay is worn out . i would replace the relay and if it won't start then it may be the compressor . example out 10 friges with this problem 1 will be the compressor and 9 will be the relay. you can also use a 3 or 4 in on kit these help old comp. start easy and keep them running . mm hope this helped . feed back pls .
Dec 12, 2010 | Refrigerators
LE40S86BD SAMSUNG, SOUND BUT NO PICTURE!!!!
One of the things the manual says is to carry them in a specific manner. If you dont the frame twists and plugs and cards come adrift.I suspect that is the crux of your current problem.
Please rate the help++++Thanks for using Fixya
Sep 23, 2009 | Televison & Video
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Won't start, no click, leave for a while turn key it starts.
See if pulling up on the shifter lever makes it start.  You may have a bad switch.  Or try cleaning the battery terminals and retightening the battery terminals solves the problem.
Dec 23, 2008 | 1999 Buick LeSabre
Samsung LE40R7 LCD TV Attempts to switch on with an audible click but a few seconds later clicks off. It then repeats this on / off clicking on its own ad infinitem.
Nothing to do with the remote! - It's either the main PCB or the power board depending on exact version of model - how old is it?
Mine is doing the same it's just over 2yrs old.
I would contact your local samsung authorised repairers and get samsung to pay for the replacement part as I will be doing tomorrow.
Aug 13, 2008 | Televison & Video
Double vision on my samsung HDTV 1080i
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Sep 16, 2007 | Sony KP-53S65 53" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
