Question about Moen Plumbing
87400leak at base of spout
87400 leak at base of spout
  • 129 Answers
The O-Rings on the body of the faucet need to be replaced.
Posted on Sep 29, 2009
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
Need to replace O Ring but cant pull the spout off
there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
Aug 24, 2012 | Moen Monticello Single-Handle Kitchen...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
I am leaking at the base of the spout. if you put any kind of pressure on it to move it from side to side it leaks. this is a two handle kitchen meon faucet
At the base of the spout it should have an o ring on the spout does it have a nut or cap on the spout that will unscrew to gain access to it. turn water off first.
If it is loose you could try tighting it , but most of the time it would be th e or ring.
May 15, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Faucet leak from the connection with spout.
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Dec 29, 2008 | Plumbing
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Plumbing Logo
166 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
