Question about Dirt Devil Featherlite Deluxe Bagged Upright Vacuum
Bolt on wheel snapped and unable to fix as the end is in the hole. Is there a way to return the item and has it happened before?
    Problem Solver:
  • 33 Answers
There is a tool to remove broken bolts and screws at hard ware store, probably under $20
Posted on Sep 28, 2009
My Neato XV-12 runs for only a few seconds and stop. The message says, please dust me off I cant see. I have dust and cleaned my neato and it still says the same thing. How do I fix this problem?
Hi Guys
I've fully dismantled my Neato XV-21 to locate the source of the "can't see" problem. (And also replaced a tight wheel Motor causing a "something is caught in my right wheel" message)
There several screws underneath the Neato XV-21 that must be undone to allow the top to be separated. A bit of a pain just to get into the visual sensor area. But not too hard with an electric screwdriver.
There is a Laser device & a Photo sensor mounted to a black plastic rotating wheel which is covered by a black cap with 2 holes in it. One hole for laser beam to exit & one to pick up return laser light return data. They are both rotated by a motor & pulley via a rubber "o" ring which could slip, break or get hairs caught in it.
These could be the source of problems. Once mine was cleaned & checked I had no more problems. Then the wheel motor got tight. Replacing the motor fixed the problem. This requires hoping the Motor Gear Box assembly out by poping the pivot shaft out of it's plastic holder. Then disconnect the spring & cable connector. But you bust be prepared to carefully remove the magnet off the motor shaft (vice & 2 flat blade screw drivers) then unsolder the small PCB at 2 points. With practice (twice) I can now replace a motor in 20-30 minutes.
Hope this Helps some Neato Users out there
Cheers
Trevor
neato-xv-12-runs-only-few-seconds-stop-qnpe3nojpvl4vx0tieerofmg-2-0.png Wheel Motors Here
Wheel and brush motor for Neato XV 11 XV 12 XV 14 XV 15 XV 21 XV Signature...
Apr 05, 2015 | Neato Robotics XV-12 Vacuum System - White
My wheel fell off where cani get it fixed
Those wheels have a fixed axil that goes bad. A new wheel will fix that.
Sep 05, 2014 | Vacuums
What kind of screw assembly is needed for the top cord holder piece on the Riccar 8900 vacuum cleaner?
There is an L shaped bolt that inserts into the hole in the handle, there are washers, a spring and a nut. I have all the items in my retail store. Most Riccar dealers will stock the items you may need.
Aug 25, 2014 | Vacuums
G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
Apr 21, 2011 | Kirby G5 Bagged Upright Vacuum
I took apart my eureka quick up vacuum and am not sure how to re assemble
I just did the same thing and had to reassemble also. I recommend turning it upside down. First make sure the belt is wrapped around the motor threads as well as the brush threads, then rest the brush more or less where it goes in the front of the vacuum. The white plastic pieces each have a small hole - you need to insert one end of the brush into each while plastic piece. When you lie the plastic piece flat you should see that the other end fits together with the top of the vacuum. The trickiest part is getting the tiny little wheels into place. Just worry about the 2 in front first. Set them carefully into place in the square holes in the front corners of the machine. Use your finger or a screwdriver to fit the mini axles properly into the grooves. Carefully push the bottom of the vacuum into place until it seems to snap in place (be careful that the wires are tucked in well) and screw in the 4 main screws. Final step is to reattach the smaller black cover to the bottom (back) side - be sure to get that wheel in place before fitting the cover on and then tighten up the final 2 screws.
Mar 25, 2011 | Eureka& Cordless Quick Up Vacuum
When the cord is pulled out, it won't stay pulled out. It snaps right back in.
Use a small item that will fit snugly between the cord and the rim of the hole. This should keep the cord at the position you want until you can take it to the shop for repair. It's best if the item is rubber, foam, or a similar soft item that won't damage the cord.
Mar 01, 2011 | Hoover Vacuums
Bissell 6590 wheel unit pins snapped, where can I get a replacement part
This is a very easy repair. I got a hose clamp. 1/2" wide, solid edge. Take your time and bend it the inside shape of the holder. drill 2 matching holes, It's a perfect fit.
Nov 02, 2008 | Bissell 6590 CleanView Bagless Upright...
Hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
Oct 04, 2008 | Hoover Elite U5061-900 Bagged Upright...
Dirt Devil Featherlite Deluxe Bagged Upright Vacuum Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
