Question about E-Machines eMachines Monitor E15T4
Hi, my 9 month old emachines monitor keeps turning off by itself, sometimes as much as five or six times a minute, otehr times not for 30 minutes. Any ideas?
Need instructions on use of the menu button on emachines E202. No instructions in package.
Posted on Dec 07, 2009
  • 137 Answers
Sounds like its the motherboard that is failing.
Since it's only 9 months old it should still be under warranty.
This computer will need to be taken in for service and the motherboard replaced.
Posted on Sep 27, 2009
Refrigerator intermittent humming sound
If it's not causing any problems to the overall operation of the unit itself, I wouldn't worry about it.
May 14, 2012 | Sub-Zero Refrigerators
Television turns itself off after being on for about 10 minutes
Run the diaginostic that you find in the pdf user manuel...1st
Nov 11, 2009 | Mitsubishi VS-60705 60" Rear Projection...
EMachines E19T6W monitor turns itself off and on.
First off, I would check the monitor, if it is getting very warm, I would use a can of compressed air to blow the dust out (make sure it is unplugged first!). Second, I would check for any sort of interference in the vicinity (speakers are a huge cause of problems in Monitors) such as magnets.
Oct 27, 2009 | Computers & Internet
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Monitor restarting randomly
Rarely does a monitor go out due to drivers. Try another monitor and verify that it isn't the computer (it isn't). If the power light goes out it is the power supply (usually inside) the monitor. If the light stays on, it will most likely be the backlight power unit. Browse the internet for the model and parts. Newer units are difficult to find.
Apr 29, 2009 | Computers & Internet
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
E machine monitor
Check the settings control panel, power options to make sure the setting is not engage to power saving after "minutes" if it is change to the require time or disable, then apply the settings and exit. if this is not the problem, the other most common problem with these emachines and random and frequent unplanned shutdowns is a the motherboard itself. Contact me for further support on this item
Jul 15, 2008 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Monitor E15T4 Logo
355 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
