Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer will run, buy does not heat up. I have model MCE8000AYW. I runs like normal, but does not heat up. We just moved and I had the dryer plugged in, but the dryer breaker was not turned on. I turned the breaker on, and it immediately tripped the breaker. After that, the dryer seemed to function properly, but did not heat up. I was wondering if there is some sort of fuse in the dryer itself that I could have blown.
    President:
  • 1,197 Answers
First, in many cases, the dryer actually IS heating, but there’s just not enough airflow out the vent to take advantage of it, so the end result’s the same as ‘no heat’.So first determine that there’s a strong flow of air out the vent. I can’t stress this enough - low airflow’s the no. 1 cause of dryer problems, not to mention dryer fires. Then check if there’s any heat in the drum when running empty. Note: there's finally a simple, inexpensive tool to test airflow in Whirlpool-built dryers!
If there doesn’t seem to be any heat at all, first check for 240V present at the dryer. I can tell you that many hours have been wasted over the years by not *doing this first*!Neglecting this is probably THE most common mistake of the novice appliance tech (and some pros who should know better! <g> ).
If you have a voltmeter or 240V bulb, just check for 240V at the dryer term. block, and you will save some aggravation and possibly a service call.
If you have no way to test this, or you are at all uneasy about messing with 240V (you HAVE read my disclaimer, right?), just go to your breaker box and throw the dryer breaker off/on several times.(If your dryer is connected with fuses, replace both of them and try it again.)Sometimes - just sometimes - resetting the breaker will restore 240V, especially in damp basements.
(On the handiest tool list: a 240V/10W bulb with leads/alligator clips, carried in your pocket - a real timesaver, and far superior to neon testers)
How you proceed from here depends on your abilities, and I’m not able to get too involved in this short article.I’d probably suggest calling a pro if you’ve proven 240V to the machine, there definitely is no heat, and there’s plenty of air out the vent. A pro sees this problem every day and can usually diagnose it in 10-15 minutes.
I will say to those of you who are ‘handy’ - start at the heat source and work *backwards*.If there’s nothing obvious (burnt wiring, etc) attach that 240V bulb to the element leads (or gas valve 120V supply), and fire the dryer up.
Light = open element (gas control/ignition system problems).
No light = other problems (thermal fuse, t'stat, etc).
Keep it simple.This one usually is.
courtesy: davesrepair
regards
iversh
Posted on Sep 27, 2009
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Model MCE8000AYW, Lower dryer section - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 14, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Maytag dryer model MCE8000AYW is overheating
with the unit over heating the problem would have to be the thermostat try replacing it and i think it will work fine.
good luck
Jul 12, 2010 | Maytag Dryers
Maytag dryer model mce8000ayw
We are having a similar problem with our dryer. Were you able to resolve the issue? Was it a coin?
Feb 24, 2010 | Maytag Neptune MCE8000AY Electric Dryer
I have a maytag dryer model number is mce8000ay
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Runs but won't heat up
the heat element was most likely broken in the move have it changed
Feb 12, 2009 | Dryers
I just moved and my LG dryer does not heat up.
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
Dryer not heating!! Harmony dpgt750ec
If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this. Good luck to you, mca0824@aol.com
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Maytag Neptune MDE5500AY Electric Dryer Logo
313 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
