My laptop isnt running fast any more and error keep coming up and saying missing files
  • James Chavez May 11, 2010
    If you would I need more information. I need to know what programs you have recently installed. What OS system are you running. When was the last time you did a disk clean up and defrag. Are you running a virus program and which one, some drag systems down. Do you know what programs are loading at start up. What missing files does it say your missing. When did you start to notice this problem. I you would let me know these things and I sure I can help you. JimmyC
    Problem Solver:
  • 10 Answers
Reinstall the operating sistem
Posted on Sep 29, 2009
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Can't reboot starts out li9ke noremal trhen a very quick blue screen and i have to restart the boot process all over againj
I came across this kind of situaiton on my HP laptop (win 7) and ended up with eliminating it with a boot program called BuitSuite and it helped entered my Windows and resolved the program. It seems that there is a system file missing which lead to error loading error when you boot. Hope it will also help in your case, best regards.
May 22, 2011 | HP Compaq nx9010
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
I keep getting an error saying: propsys.dll Missing
http://www.fix-all-dll-errors.com/propsys.dll/
You can find it here...just follow the link.
Mar 21, 2010 | Lenovo ThinkPad X301 Notebook
Says \windows\system32\config\system is missing or
If you are getting this error message first diconnect the printer and network cable. After that disconnect all USB devices.
Then Restart your computer and go to BIOS set all USB devices to no boot.
Feb 25, 2010 | Dell Inspiron 6000 Notebook
Sony laptop model:pcg7m1l
do you have more than one hard drive?
if this is system drive you may reinstall system or try to recover missing files.
Aug 12, 2009 | Computers & Internet
Screen says NTLDR is missing.
hello friends..
Ntldr file is essential file in order to boot system...If it is missing then your system wont start..try to repair this file from XP/vista CD .. then problem will vanish
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dell 100l ntdrl missing on start up
For some reason your boot files are missing.
ntldr ( NT loader ) is one of the main boot files that is missing.
possibly a boot sector virus.which corrupts the ntldr file.
Put the disc back in, and you can choose to either install the O/S, or you can repair the current O/S, go for the repair,
Should resolve the problem,
Then run a full system vius scan,
Should be good then
Regards
Richard.
Apr 20, 2009 | Dell Latitude 100L Notebook
Computers & Internet Logo
711 people viewed this question
David Payne
David Payne
