Question about Toshiba EKT 6010 S Corded Phone
# key doesn't work and it doesn't answer directly when picked up. ( model EKT6010-SB 1999)
  • 647 Answers
It sounds like the contact for the # key is sticky or bad especially if this key is used alot. The contact can be cleaned by removing the keypad and wiping the contact with head cleaner or rubbing alchol. As far as it won't pick up -check to see that the handpiece contact switch comes up all the way - It may need adjustment or cleaning as well.
Posted on Sep 27, 2009
1999 buick century abs lights on trac light or no trac directional makes a loud noise when i try to use it and now it only starts once & awhile with the key
check the ABS sensors in each wheel may be dirty clean them but may have to clean the pick up in each wheel as it is teeth fitted to the shaft.
Dec 23, 2013 | 1999 Buick Century
My nikon d90 doesn't works when i put the flash sb-600
Could you provide some details? How does it not work? Does the D90 not turn on? Does it take a picture but the flash doesn't go off? What exposure mode(s) are you using?
Apr 02, 2013 | Nikon Speedlight SB-600 TTL Flash
Need schematic drawing for sds2 inter motherboard
Best I could do was find it in Chinese. (?????????) from Intel Support,
http://www.intel.com/support/motherboards/server/sds2/sb/cs-006801.htm?wapkw=intel+server+board+sds2+product+guide+english,
,but in English from a quick browser search,
http://download.koncar-inem.hr/public/serveri/LEA_SDS4/sds2_pg.pdf
(If it doesn't work as a direct link you just click on, then copy it (CTRL + c ), and paste it (CTRL + v ) in your browser address bar, then press the Enter key.
Regards,
joecoolvette
Nov 13, 2012 | Intel Server Board SDS2 Motherboard
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
Directing Creative Soundblaster X-Fi synths to SPDIF
I have researched this same problem with my SB X-FI Fatality Gamer Edition and the answer I came up with is that you cannot output sound ( at least not 5.1 surround sound ) through the SPDIF out. Supposedly, this port is used for " some other reason " that I could never clarify. The only solution I ever uncovered was to buy the breakout box for the sound card.
Sep 27, 2009 | Computers & Internet
SU-800 and SB-600 line of sight
Remember that the SU-800 works by sending out an infra red beam as the trigger pulse, when out doors available light can swamp the sensor on the side of the flash with too much light, therefore the flash cannot "see" the pulse from the SU-800.
Also if you refer to the manual, you will find nikon recommends working within approx 30 / 60  degree angle of the sensor, so if you were working behind the camera with the flash it would have had even more trouble.
As you found when you used your hand you strengthened the output beam for the flash to be able to pick up the pulsed output beam. You may need to create some kind of hood, to place in front of the SU-800 to direct the beam in the direction you need it to work.
Hope this helps  Ian
Aug 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Where can I buy nikon sb600 and sb800 spare parts. Need replacement infrared covers.
You have to order parts from the Nikon authorized service rep for your area. Call Nikon tech support for information. In some areas, Nikon will sell direct.
Jerry G.
Apr 05, 2008 | Nikon Speedlight SB-800 TTL Flash
Toshiba EKT 6010 S Corded Phone Logo
49 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
