Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
I have a Kenmore electric range.Convection,self-cleaning.Approx.10 years old.I cannot get heat from the bake or broil elements.No codes are showing and the module seems to do its functions.I have change the fuses and check the breaker.
    President:
  • 1,304 Answers
Sounds moree likely that you lost one side of your power
check your voltage at the outlet
l1 to ground 120
l2 to ground 120
l1 to l2 220
Posted on Oct 05, 2009
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Sears (Kenmore) drop-in unit, Model 911.4698815. Ran the self-cleaning cycle - now it's showing Error Code F3 and neither the bake element nor the broil element will work. Any help would be...
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Sep 12, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
172 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
