Question about Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook
Toshiba P35-S611 will not come on.
When you push to power button to turn it on, the blue power light around the button comes on, the system fan come on for 3 to 4 sec and then the fan stops and NOTHING happens. Any ideas?
  • 188 Answers
Simplify -
1.swap between both sticks of ram.
2. remove hard drive (should be right on the bottom near the RAM cover.
3. Remove CD drive (usually just one screw on the bottom where the end of the drive would be)
If those dont help, then its likely a CPU or motherboard problem which would require a lot of disassembly of the system to check.
Posted on Dec 17, 2007
Satellite P35-S611 (PSP30U20H001) PC Notebook: what causes the p 35/30 shut down as soon as you t...
The processor is over heating. I have a p-35 s6053 and it used to do the same thing until I fixed it.
Do the fans come on or anything when you first try to turn it on ??????
I'd bet the fans come on strong and then after about 5-60 seconds it just shuts off. let me know if i'm right and I can tell you how to fix it,
May 17, 2010 | Toshiba Satellite P35-S611 Notebook
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite laptop Model 035 S611
If it is completely frozen press and hold the power button (you will lose any unsaved work) it should turn off, failing that remove the power source.
May 18, 2008 | Toshiba Satellite P35-S611 Notebook
My satellite P35-S611 will not run on AC power nor will it charge the battery
I have just fixed the same problem on my Toshiba p35 s611.
The power jack inside the laptop had been damaged. To reach the problem you must take apart the entire laptop (there are a few guides for doing this online). Next I simply found the positive connection coming from the jack (it is the wire coming out of the back of the jack) and followed it to where it enters the motherboard. I simply flipped it around and re-soldered that one spot. Other sites recommended I remove the jack but I couldn't melt the solder enough to do so, however just trying and adding some fresh solder was enough to fix the problem. I no longer need to jiggle the power connector to the right angle just to get power.
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
Missing P35-S611 Restore CDROM
Sorry but that would be illegal :(
Contact microsoft for a replacement.
Jan 05, 2008 | Toshiba Satellite P35-S611 Notebook
Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook Logo
62 people viewed this question
Alun Cox
