Question about Samsung Televison & Video
SAMSUNG T.V MODEL; CS-29Z40HE This T.V buy on JULY 2007 PROBLEM; No power; total dead; no red led stby; have beep sound...tick...tick...like not enough power when power on (maybe sound come from relay). The fius checking is o.k.
  • Samsung Master
  • 1,297 Answers
Check the PTC parts,the primary AC power supply board.Disconnect the power supply board,measurement the capacitors and power tranzistors,measurement the output voltage(155V),connect on the output on 60W electric bulb,if it light the power source is ok and the problem in the horizontal driver parts(trafo,power tranzistor...).
Posted on Sep 27, 2009
TV cannot turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Action-3: Replace the main board!!!
Mar 25, 2017 | Hitachi Televison & Video
How do I connect my PS2 to my Samsung CS-29Z40HE 29" SlimFit
the jacks on side and or back are AV inputs and your unit connects to them and then you select the input with the remote or via the menu.
Either you are not connected correctly or not on the right input or a mismatch of some kind exists
Mar 14, 2012 | Televison & Video
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
My television will not turn on. I made attempts to switch outlets and turn on the television manually with no success. I can tell the television is not taking any juice because the standby light is no...
No power to the tv at all?No,LED power light indication or no LED power standy light.The tv power supply board is dead.That the board,where it take in the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 13, 2010 | Element Electronics 26 in. LCD TV
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
Daenyx DN26D
We are experiencing the same problem with our DN26D...we'd purchased this TV back in July at WalMart in Toronto in September 2007. We have now only a blue screen and after reading through the poorly written manual we are unable to troubleshoot. Auto tuning has done nothing and switching channels has proved even less. Before sending the model back to the manufacturer could anyone suggest what we can do?
Dec 25, 2007 | Televison & Video
Televison & Video Logo
316 people viewed this question
Henry  Thomas
Henry Thomas
