Question about Royal Office Equipment & Supplies
The royal paper shredder we have when plugged in does not operate. The power light does not even turn on. Is the motor burned out? thank you, garagesailor2003@yahoo.com It is an MC5
    Genius:
  • 1,218 Answers
If its "dead" you probably need pcb...call Royal at 1-800-524-0799 for assistance.
Posted on Oct 10, 2010
Royal 1212x power light goes on but machine won't shred
Burned out shredder motor maybe or the sensor that senses paper is broken or defective
Nov 18, 2016 | Royal Office Equipment & Supplies
After cleaning my shredder Royal MC9 and waiting for more than 30 minutes unplugged, I can't restart it and the power button alaways stay off (as with no electricity) Do this shredder have a reset? I
There is a thermal switch in a shredder for situations when the paper gets stuck in the rollers and the blocked motor is overheating.
Usually the thermal switch is reversible, ie after cooling down the unit powers on fine. To my knowledge there is no physical reset needed.
However, the motor itself may have a secondary thermal fuse inside it's winding, and this one usually is single-use: when it blows - the motor needs to be repaired.
If waiting even more doesn't help, and you indeed triple-checked the safety interlock features, then it is possible that a fuse is indeed blown and the unit needs inspection by an electrician.
Nov 24, 2014 | Royal Office Equipment & Supplies
I have a royal shredder modle MP220 the motor is running but it doesn't will not pull the paper in . I cleaned it out and still nothing .
It is possible the blades are running in reverse. If the motor is running and the blades are turning without putting paper in, check the position of the switch. The motor should not turn on automatically when repositioning the switch. Reposition the switch so the light is on, but the motor does not run. Then try to put in paper. I hope this helps.
Apr 19, 2014 | Royal 160MX Shredder
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
While attempting to feed paper overload light comes on and shredder stops
Over load light comes on only when you have either put too thick a bundle of paper or too hard. So reduce the thickness according to the hardness of the paper. Start with a few sheets of paper only. then increase the number of sheets till you find the shredder is struggling hard to do the job. That is your limit. If you exceed this limit then it would stop shredding and may even burn the motor ultimately.
Nov 29, 2009 | Royal VF1012mx Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Jun 14, 2007 | Royal VF1012mx Shredder
183 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
