In Duplex Printing, page 2 prints upside down. How do i get it to print both sides
up right?
SOURCE: duplex printing
I think you given the wrong printing on one side. So Check the page orientation and do the printing
SOURCE: Printing a book from Word using duplex printing
In the Printing Preferences window, on the Page Setup tab, you have already selected Duplex Printing and Automatic. If your book is to be bound on the long side, you should have 'Long-side stapling . . ' selected in the window below that.
If that is what you have selected and the pages are printing wrong, try the 'Short-side stapling . . .' option.
SOURCE: Canon MP610 Printer When automatic duplex
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
SOURCE: Duplex printing flips page
That should be a setting somewhere in the printer or the print driver on the computer.
Here's a link to the manuals that comes with it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=16279#DownloadDetailAct
SOURCE: Mottled effect on one face during duplex printing
that would b the fuser if it has build up on the rollers.. definitely change out the magenta toner and verify that the paper stock is within specs!
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
