Question about Toshiba 27A41 27" TV
I have a toshiba 27a41 model tv where do i hook up an antenna
  • 647 Answers
Hok it to the cable in connector that says "in from cable or VHF or Ant in" You may need a 300-75ohm adapter depending on your antenna
Posted on Sep 27, 2009
I have a Toshiba tv and I need to hook it up to my direct tv box and all I get is snow. Please help
snow is an indication that the antenna is not properly connected
try connecting the antenna cable to the input of the box then from the box to the input of the tv
follow the user manual directions
Feb 08, 2016 | Toshiba Televison & Video
Reset factory
Without knowing the code, you can't unlock it. Contact the authorized service center for Toshiba.
Dec 12, 2013 | Toshiba 27A41 27" TV
What other devices do I need to make my toshiba 35A44 tv work
It needs to be a digital antennae and digibox,then go on digibox and scan for channels
Aug 23, 2012 | Toshiba 35A44 35" TV
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
What channel is the s vidio channel ?
s video is the channel you see when you select input on your tv and it shows the device you hooked up to the svideo port on your tv..its different for every tv. ex: You plug in you dvd player to svidoe on your tv..select your input till you see what the dvd player is playing.
Jun 15, 2010 | Toshiba 27A41 27" TV
How do we make my TV capable of receiving regular local channels without cable or satellite hook-up?
You would have to hook up an external TV antenna on the UHF/VHF band and run a coaxial cable from the antenna to the TV and plug in the "Belling-Lee" connector into the "Antenna" socket at rear of unit.. This should enable reception via "Normal TV"
Jan 24, 2010 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Toshiba 27A41 27" TV Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
