Question about Emerson Televison & Video
Code for fios cable remote from an emerson tv how can i program to the one fios remote
2 Suggested Answers
PyroMan6x9x9
  • 150 Answers
SOURCE: Emerson Remote code
Get back to me with model and make of the remotes themselves, I'll see what I can find. Or you can check out http://www.xdiv.com/remotes/ Good Luck
Posted on Sep 14, 2007
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Ok i have a rca remote trying tp program it to a emerson tv do not have any codes
Here are some codes for your Emerson TV.
065,067,075,076,079
011,026,027,028,029,030
031,032,037,042,053,064
Here are some instructions as well for your RCA Remote:
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Hope that helps.
Aug 22, 2010 | RCA Universal Remote Control
Remote comtrol
Depends on the make of your TV. Here is a link that shows, step by step, how to program your Fios without a code.
http://www.ehow.com/how_5066834_program-fios-remote-code.html
Sep 29, 2009 | Computers & Internet
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
May 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
None of the emerson codes work with my Philips remote
point the remote at the TV while it is on and press the ON/OFF switch for 2-5 seconds when the TV shuts off..... that is the correct code, then lock it in....!!
Mar 27, 2009 | Televison & Video
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Magnavox tv dvd combo
This is interesting. I have the same TV/DVD combo, lost the original remote and have Verizon FiOS. I cannot get ANY code to work the TV on the universal FiOS remote, not even the Magnavox codes suggested by Phillips, the remote manufacturer.
Jun 18, 2008 | Televison & Video
Codes
I have the same problem with the Cox Cable remote attempting to make it recognize my Emerson model LC320EM8 HD TV. The booklet with the remote shows 20+ codes for Emerson TVs and I tried them all, I then tried the channel up/down search, to no avail. Is there a code for this TV, or do I have to buy another Radio Shack universal remote like I had to do with my other TV home theater system?
Dec 04, 2007 | Televison & Video
Codes
i need help i have a emerson tv but the remote is geuniversal i need the code please
Dec 02, 2007 | Emerson TS1997 19" TV
Televison & Video Logo
153 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
