Question about Kidde Nighthawk Combo Gas/co Detector
It keeps bleeping every thirty seconds when plugged in to the mains do we need to worry
    New Friend:
  • 36 Answers
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better
Posted on Sep 28, 2009
Testimonial: "THANKS 4 THE ADVICE YEAH IT IS 7 YEAR OLD , SO I WILL REPLACE IT ."
    President:
  • 2,600 Answers
I own several of these and they are thrown away. The sensor gets staurated and needs to be changed, more financially feasible to change the entire detector out.
    President:
  • 1,187 Answers
The unit has "malfunctioned", you should also have an "ERR" message in the display.
It has a five year warranty. Do not try to "fix" it. Replace it under warranty. If it gets "repaired", get another one, but plug this in, anyway. (two units in same area).
My caso wine fridge right hand temperature reading just keeps bleeping You hold it down for 10 seconds and it stops and then starts bleeping again
Check out their website, you can choose your model and download the manual. If it's not in the manual then give the manufacturer a call.
http://www.caso-germany.com/en/cooling
Jun 07, 2016 | Furniture
I dont want to look at the No HDMI Cable Message after the computer shuts down. Is there a way to make the screen go blank more quickly. Or do I have to watch the message scroll across the screen for 10...
A couple of options. First and cheapest, you could turn off the monitor. Second, for about thirty to fifty dollars, you can pick up an energy saving surge protector. With this, it has a main plug, and switched plugs. The switched plugs cut power when the main item is turned off. I.E. PC turned off, monitor, speakers, printer all turn off a moment later.
Dec 11, 2011 | Dell ST2420L 24 inch LCD Monitor
After being reset and plugged back into computer to charge, a red light pops on as soon as plugged back into usb port to charge and will not turn on.
Put a pin in the reset button situated in the tripod hole.Do it three times for about thirty seconds each time.Also depress the on off switch for about thirty seconds.Put it in the usb port of your computer to charge.After about thirty minutes or an hour the screen should go white.A battery shows on the screen.Wait till the battery shows all green,then it is fully charged.
Oct 28, 2010 | Pure Digital Flip Mino Digital Camera
I have a 1997 2.5 jeep wrangler.when you first start the engine it runs and sounds fine, then after about 20 seconds it begins to have a knocking sound only at idle. when you press the gas you cant hear...
It may be piston slap. This is caused by either engine wear with the piston bores being too large for the pistons, or by poor manufacturing tolerances, or a combination of both.
To test for this, start the engine up first thing in the morning and run it for about thirty seconds while you listen carefully and memorise the sound and intensity. Turn the engine off quickly, remove the spark plugs and put two squirts of motor oil into each cylinder. Reinstall the plugs, start the engine up again and listen. If you have piston slap the noise will have been greatly reduced or even eliminated for about thirty seconds seconds and then returns.
The fix is to rebuild or replace the engine, but if it works just fine then don't worry. Many slappy engines keep going for tens of thousands more mile. The fact that your knocking is only at idle suggests your crankshaft is not to blame.
Sep 26, 2010 | 1997 Jeep Wrangler
Psp wont connect wlan
1. make sure the WLAN Switch set to the on position. 2. make sure your network settings are correct i.e.:WEP Key is correct 3. unplug your router, wait thirty seconds plug it back in and try connecting again.
Aug 15, 2010 | Sony PlayStation Portable (PSP) Console
The flame goes out after about 30 seconds. I have
one of the thermal sensors may be bad.
you may also have a faulty ignitor even though it glows it maynot be drawing enough current to keep the regulator open
May 28, 2010 | Maytag Neptune MDG7500AW Gas Dryer
Hi i cant get it to flash so i can pair up.it just keeps beeping at me when i hold the button in on my ck-7w bluetooth car kit
you may need to find the main junction box and disconnect it for a few minutes to reset, they commonly lock up and need to be powered down, then hold down the nokia button for 10 seconds till you hear a bleep and it will allow new pairings, the passcode is 0000
Feb 11, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Oct 06, 2009 | Philips Lands Phones
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Flip video mino troubleshooting freeze
There is a reset button! Get a pin and push into the tiny hole at the bottom - inside the tripod screw hole. Push in and hold. The camera will reset. I called the Flip support - they were great !
Apr 05, 2009 | Pure Digital Flip Video Ultra Camcorder
Kidde Nighthawk Combo Gas/co Detector Logo
655 people viewed this question
Top Kidde Home Security Experts
richie46
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
