Question about HP Media Center m7060n PC Desktop
Memory card reader not Reading at all!
My memory card reader isn't reading the cards now. I did just get it back from Microcenter and had the motherboard replaced. Is it likely the tech did not connect the reader to the motherboard??? I haven't had problems with the reader before at all!
Hi! I had the same problem. The tech accidently pulled the cable out. Either put the cable back in or take it back to the tech...
Posted on Dec 17, 2007
STORAGE CARD NOT WORKING - Your memory card has changed is damaged or is non-compatible. To fix this, turn your phone off and either remove the memory card or replace it with a new compatible card. Then...
To check your memory card ,you need a memory card reader.
insert your memory card into the reader and connect the reader to the USB of your PC. save your data if needed.
if its reading try to format it in your Pc by right clicking the mouse.
format option. then insert the MMC back to the phone and format it in the settings menu/storage.
your memory card will work fine.
if you cannot format using your PC replace the memory card.
Dec 09, 2017 | HTC HD7 Cell Phone
Why is my memory card reader not reading memory card?
What type and size memory card? What card reader? Is the card reader compatible with it? For example, SDHC cards will fit into an SD card reader, but unless the reader was designed specifically to be compatible with SDHC cards as well as SD cards, it won't work.
Jan 09, 2013 | Cameras
Our printer will not recognize our memory card. We are inserting it in #3 slot. This card was used in a Cannon EOS 60D camera. It will pull up cards from another camera.
Try reading the card with another device such as a computer card reader, also make sure there isn't some sort of lock switch on the card. If the card will not read in another device it is probably faulty and needs to be replaced.
May 11, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My memory card of n73 had stopped working and the card reader is also not able to read it . What can i do now?
Please try a different card & confirm that your phone card reader are working or not. If its working then you sure that, you r memory card have problem. So try to format it and then use. Some time virus's block the card.
If you seen that, your phone does not read any card then visit the nokia service center and give them for service/ internal dust cleaning.
Thanks.
Feb 11, 2010 | Nokia N73 Music Edition Smartphone
My memory card is corrupted .in memory card reader it is not reading .. plz tell me wot to do!! my memory card reader donot access memory card and my nokia 6630 also donot detect my memory card.
Memory cards are easy to just blow up and quit. Looks like this is what happened to yours. I suggest you get a new and save what info you can before you lose more. Sorry.
Sep 29, 2009 | Nokia 6630 Cellular Phone
Computer not reading memory card :(
I will assume you have rebooted and that the reader is enabled. Do you have any mapped drives? If so try to remap so you have Drive F & G available.
Jul 07, 2009 | Computers & Internet
Sony Memory Stick PRO Duo Not reading
Get a USB card reader, insert the memory card into the card reader and then connect the card reader into the USB port of your computer.
The computer will see the memory as an external memory device, now you can view the data/images and copy them to your computer.
Feb 13, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a compaq presario sr1230nx and when i go to put in a ad card the light next to the slot blinks green and then the card cant be read. then the explorer crashes for about 20 seconds and then i tried...
The memory card reader on your computer may not be able to read memory cards over certain capacities (4 GB).
To use your higher capacity memory card without locking up the computer, do one of the following:
  • If you are using the card in a camera or other device, you can attach the device to the computer using a USB or FireWire cable. When connected, most devices appear in Windows as a Removable Disk and can be used in the same way as the card reader.
  • Purchase a USB memory card reading device that plugs into any open USB port. Make sure the USB device is capable of reading SDHC. These devices are fairly inexpensive and can be used in any computer that has a USB port.
If the card reader stops working after using Safely Remove Hardware, reset the cable connections and memory card firmware.
Memory card appears in My Computer but errors occur when writing or reading
If you are having problems reading and writing data to memory cards, use the following troubleshooting tips:
  1. Try a different memory card of the same type in the same slot. If the different memory card works, the card reader is good and the original memory card should be replaced.
  2. Some cards have a read/write security switch on the card. Make sure that switch is set to Write Enabled before attempting to write data to it.
  3. Make sure that the amount of data you attempted to store has not exceeded the capacity of the card.
  4. Inspect the ends of the memory cards for dirt or material closing a hole or spoiling a metal contact. Clean the contacts with a lint-free cloth and small amounts of isopropyl alcohol. Replace the memory card if necessary.
  5. Make sure the memory card is one of the supported types: CompactFlash (1, 2, and Microdrive), Memory Stick, MultiMedia, Secure Digital, or SmartMedia memory cards.
  6. Make sure the memory card is fully inserted into the slot.
    Remove the memory card when the light is not flashing and shine a light into the empty slot. Are any small pins inside bent? Replace the memory card reader or have the computer serviced if a pin is touching another pin. Straighten slightly bent pins while the computer is off using the tip of a mechanical pencil.
  7. If errors persist replace the memory card.
Dec 20, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Camera not reading SD card after being removed from my reader
Put the SD card back into the card reader. Are you files still there when the computer tries to read them?
If they are not, then it is very likely the card is corrupt. This happens when the card is removed before the computer is done reading/writing to the card.
There is also a SLIM chance the card is just bad.
Nov 06, 2008 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Computer is not reading my Micro SD, but phone is reading..
What size is the SD card in GBs? If it is larger than 2GB (4 or 8) do you have a SDHC card reader?
Also try formating the card first in the phone and then using it. Using it straight out of the package, while able to be written, my have difficultly with other devices reading the data.
Jul 23, 2008 | PNY 2GB microSD Memory Card
HP Media Center m7060n PC Desktop Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
